Forum Index : Microcontroller and PC projects : Computer from the Chernobyl zone....
This is actually quite interesting. I'm amazed that the radiation has not destroyed the chips or otherwise done damage enough to prevent the unit from booting at all, but..... Chernobyl Computer... Smoke makes things work. When the smoke gets out, it stops! |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6200 |
Not surprised. It is silicon from the 1980's. There where no small geometries, not atom deep doping. For radiation to destroy old silicon it must be really high dosis (so taken from the reactor building inside the coffin). But take a modern (11'the generation i7) CPU there and it will die in weeks. Volhout PicomiteVGA PETSCII ROBOTS |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9252 |
I really enjoyed that video. :) They have done a few on Russian computers. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| pd-- Senior Member Joined: 11/12/2020 Location: AustraliaPosts: 122 |
That brings back memories for me it was dec pdp11's when storage was so expensive you went to the trouble of packing 3 asci2 chars into a 16 bit work https://en.wikipedia.org/wiki/DEC_RADIX_50 Still have a VAX4000 cpu card that we usto run in a pdp11/84 chassis |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 649 |
We had a lot of DEC stuff running in our small computer center serving production. Once in a while we had a memory parity error and the account technicians first answer usually was "don't worry, this was certainly just a single alpha particle". More than once it was a slowly dying memory chip, as there was no radiation source around. Regards, Gerald 73 de OE1HGA, Gerald |
The Alpha particles the tech was talking about come from the chip encapsulation not external radiation. There are trace impurities in the plastic used that are very expensive to remove. Most Alpha particles only travel a few inches in air and less than a mm in anything solid so external radiation has to be very intense to penetrate. Military spec. chips of the era used "Alpha free" ceramic encapsulation. |
ahh tnx, didn't know that. The product line with the highest reliability, I got in touch with, was railway security. But they didn't use mil grade components either. 73 de OE1HGA, Gerald |
