Local Time 05:28 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : For Jim ref Crunch & ON ERROR SKIP [nn]
Chopperp
Posted: 12:03am 22 May 2023
Hi Jim
Question regarding  "Crunch" in MM Edit & Command "ON ERROR SKIP [nn]"
I assume it is the responsibility of the programmer to ensure that there are no commented lines within the range of the SKIP[nn] number if using Crunch?
May need a warning somewhere if there isn't already one.
Still on V5.0.5
Thanks for MM Edit.
Brian
ChopperP
Posted: 12:33am 22 May 2023
What device are you programming for?
As far as I can remember, SKIP skips over commands, not lines and comments inserted in the skip zone make no difference.
I rarely use SKIP for anything other than one command at a time so haven't had much experience with it doing the unexpected.
I think there was an issue with user defined SUBs and what to skip over but I don't remember which platform it involved.
Chopperp
Posted: 12:40am 22 May 2023
Hi Jim
OK, misread the instructions. Sorry
Using it when opening files on an F4 as it sometimes cracks a hissy-fit. Need to skip to after the Close # command if it plays up.
Will count commands rather than lines.
Brian
ChopperP
