Local Time 06:25 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug in EPOCH()?
William Leue
Posted: 05:59pm 08 May 2023
I wonder if this is a bug in the EPOCH() function in MMBASIC VER 5.07.00, or just my usual stupidity?
This little program gives me a syntax error when it hits the epoch() function:
option default integer
fname$ = "Solver.bas"
mdt$ = MM.INFO$(MODIFIED fname$)
print mdt$
secs = epoch(mdt$)
print secs
end
The date/time string printed out on line 4 looks fine: "08-05-2023 13:58:04"
But I get "Error on line 5: Invalid date"
Any clues?
-Bill
Posted: 06:09pm 08 May 2023
Which 'mite ? I don't think 5.07.00 is the latest release version on any of them.
William Leue
Posted: 06:11pm 08 May 2023
  thwill said  Which 'mite ? I don't think 5.07.00 is the latest release version on any of them.
Color Maximite 2 Gen 2. I haven't seen any more recent releases for the CMM2 except for betas, but I may have missed one.
-Bill
Posted: 06:16pm 08 May 2023
The latest release version on Geoff's website is 5.07.01.
I'm pretty sure that I've found and Peter has fixed at least one bug in the CMM2 EPOCH() implementation, but that may have been for one of the 5.07.02 betas.
Edited 2023-05-09 04:17 by thwill
William Leue
Posted: 06:20pm 08 May 2023
Thanks, Tom! For now, I will just write my own version of epoch(), not too hard.
-Bill
Posted: 06:35pm 08 May 2023
The time string from modified is the wrong way round - should be "YYYY-MM-DD HH:MM:SS". This is certainly corrected in the current beta but I'm not sure when the correction was made. in fact the latest betas allows both time formats for epoch
Edited 2023-05-09 04:39 by matherp
Posted: 07:29pm 08 May 2023
  William Leue said  ...I will just write my own version of epoch()...
http://www.fruitoftheshed.com/MMBasic.UnixTime-or-Epoch-Time.ashx
may help. written for the Micromite, works well but I think you'd be better tweaking it to fit the PicoMite because there are functions in the later basics that are not present for the micromite e.g. Field() This function works tightly with my Split() function  (which is comparable with Field) referenced in the wiki.
This UnxTime() function gets battered in loads of my code
Edited 2023-05-09 05:31 by CaptainBoing
William Leue
Posted: 08:06pm 08 May 2023
  matherp said  The time string from modified is the wrong way round - should be "YYYY-MM-DD HH:MM:SS". This is certainly corrected in the current beta but I'm not sure when the correction was made. in fact the latest betas allows both time formats for epoch
Thanks, Peter! I had just finished my code where I turn around the date fields and yes, it works fine.
-Bill
