Local Time 06:26 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New "Tiny" RP2040 module from WaveShare....
Posted: 06:18am 05 May 2023
A little bit smaller, optional add-on board with USB-C connector and buttons, parts all on ONE side, with the bottom side being flat allowing for very easy surface-mounting.
WS "Tiny" RP2040 module...
Still seems to only have the 2MB memory chip, but that is not a deal-breaker - for me.
Posted: 07:13am 05 May 2023
Perhaps they had too many "How do you expect me to surface mount this thing?" complaints. :)
I don't think I'll bother. I don't like that sort of cable at the best of times. lol
Posted: 07:25am 05 May 2023
Hate not, the FPC and connector.
They are just fine, if handled correctly.
Your stereo is probably full of them connecting all the boards together inside.
Perhaps not suitable for REGULAR use, but for occasional firmware updates etc...
IE: Develop on the Zero with the USB-C socket and buttons, then use the Tiny on the product, as once you have the program correct, you should not need to update THAT often.
They are pin-for-pin compatible, and the footprint - as far as the I/O pins are concerned - are identical.
Posted: 07:43am 05 May 2023
I've not liked the darned things since the ZX81 keyboard. I'm not going to start showing love for them now.
I can never get them to plug in easily. My fingers aren't that size or shape. The latching sockets, made by orcs in the depths of Hell, are even worse!
Horrible things...
(My stereo is all hard-wired with proper wire apart from the chinese DVD player that I occasionally use to play CDs. This I know because, apart from that and the power amps (which are guaranteed ribbon-free), I wired it all. :) )
Posted: 12:16pm 05 May 2023
I find it hard to get enthousiastic about all these derivatives.
Some derivatives refuse to run faster than 200MHz, and I don't want to be the one to find out. I'll stick with the genuine RP boards, and add peripherals per project.
I may invest in a WebMite though. Beginning to get excited about that. Especially now Geoff showed a nice web GUI running on the mite. Could use this for my son's tropical frog habitat.
Edited 2023-05-05 22:17 by Volhout
Posted: 12:44am 06 May 2023
@ Mixtel90 - LOL!!!     OK, fair enough.
@ Volhout - I still like and use the standard Pi foundation issued Pico module where I can physically fit it in, but I have many different projects that are designed to fit on a standard single wall-plate, and the standard Pico module just gobbles up way too much PCB real-estate.     That is why I am interested in all the smaller ones, cos you CAN fit them on the back of a wall-plate along with everything else on the circuit without too much difficulty.
Quazee137
Posted: 05:22am 06 May 2023
I find Waveshare has been a good source of RP2040/pico's.
 Ordered 4 of these with the the USB C add on ribbon.
 Really these would be just right for thwill's game board. As they can be flush
 mounted and have enough needed pins. Even doing a cutout using the other tiny
 pico would work nicely.
 I am looking at using these to do smart PH and conductivity of cooling tower
 water even with the lower res of the ADC's. Will allow for plain text data
 transfers into spreadsheets. Also easier calibration. All thanks to MMBasic.
Quazee137
Posted: 06:31am 06 May 2023
Hi All,
I think the concept of the USB plug in is just for programming/flashing the 2040 PCB, once done the usb and cable are removed for the small PCB to be secreted away inside some case/device.
hitsware2
Posted: 01:31pm 06 May 2023
one
two
three
four
five
Edited 2023-05-06 23:38 by hitsware2
my site
Posted: 03:16pm 06 May 2023
I prefer to stick with the original Pico. I got the YD-RP2040 modules because they were cheap and have more flash. The fact that they won't run at over 200MHz isn't of great importance for the job I have (or had) in mind for them at the time. They also happen to have four ADC ports. I've just got some of the RP2040=Zero boards because I think they'll be even better for the project. :)  In both cases the boards have USB-C connectors, which I think should have been on the original even if it made it a little more expensive. MicroUSB is ok for occasional connection, so for embedded computing it's probably ok, but did they really expect them not to be repeatedly plugged and unplugged by hordes of hardware hackers?
I do miss having a GP25 LED on the RP2040-Zero though, especially as one of the pins needed for VGA is connected to the onboard, non-isolatable WS2812.
Posted: 04:00pm 06 May 2023
  hitsware2 said  one
two
three
four
five
There are more :(
I wonder which have what problems/shortcomings/etc...
(Like not running MMBasic fully or at higher speeds or ...)
Posted: 10:05am 07 May 2023
They all run of a small lineair regulator. When the limitation is in power use, they Maybe all have the problem.
I know the switcher is Noisy, but I like it a lot.
Posted: 10:27am 07 May 2023
Agreed. The switcher is ideal when you don't need audio or low noise ADC. Both of these are better unloaded from the Pico anyway to reduce "computer hash" noise. Being able to run from less than 3V can be very useful sometimes.
