Local Time 06:24 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: getting 5V from 3.7V (VSYS)
Posted: 05:15pm 29 Apr 2023
Hi folks,
I need to temporarily tack a 5V GPS unit onto my 3.7V powered Pico Handheld - don't ask, it would just be less work than building something specific for a short-lived project.
Can I just take the ~3.7V from the Pico VSYS through one of these:
 https://www.aliexpress.com/item/1005004010491015.html
Will the circuit need any additional protection ? There is already a 1N5818 between the battery and VSYS.
Thanks in advance,
Posted: 05:30pm 29 Apr 2023
And then regulate down from 12V to 5V?
This might do a better job for you (with the emphasis on "might") if 500mA is enough:
Aliex: Boost to 5V
Posted: 05:31pm 29 Apr 2023
Yes, that will work.
Adjust to 5v before connecting gps.
Most gps will work from 3.7v though. Internally they run on 3.3 or 2.5v
Edited 2023-04-30 03:32 by Volhout
Posted: 05:32pm 29 Apr 2023
  lizby said  And then regulate down from 12V to 5V?
Huh? It's configurable, it does 5V, 8V, 9V or 12V.
Posted: 05:34pm 29 Apr 2023
Ah, sorry--I didn't scroll down to see the solder-blob connections on the back which select output voltage.
Posted: 05:59pm 29 Apr 2023
  Volhout said  Yes, that will work.
Thanks, so I should probably just try powering it directly from VSYS and see what, if any, life there is.
Edited 2023-04-30 04:00 by thwill
Posted: 07:22pm 29 Apr 2023
Looks like it should be fine, Tom. Handy (and cheap!) little board.
Turbo46
Posted: 12:28am 30 Apr 2023
  Quote  so I should probably just try powering it directly from VSYS and see what, if any, life there is
If there is no life (as we know it) can you simply use a 1.2 volt rechargeable cell connected on top of the 3.7 volt supply?
Or maybe 1.5 volt AA cell with an ordinary diode in series with the +ve (use a 10k resistor to zero volts to see the final output voltage in that case).
Quazee137
Posted: 05:32am 30 Apr 2023
I know it works in PIC's not sure the RP2040.
 Use PWM to drive a boost circuit. A lot of the programmers did that
 even made negative for old Eproms.
 Quazee137
Edited 2023-04-30 15:32 by Quazee137
Turbo46
Posted: 05:39am 30 Apr 2023
I've done that with 555s as well using a voltage doubler but I doubt the the RP2040 could provide the power for the GPS without some sort of buffer.
Posted: 07:06am 30 Apr 2023
A diode pump fed from a PWM pin will get 5V (or even -5V!) easily, but with the low current available from the RP2040 there will be very little current available. Probably only a couple of mA. Put a paralleled up hex inverter chip in as a buffer and it may be fine. However, the PCBs thhat Tom has found work out *way* cheaper and smaller than a cobbled together system and will very likely "just work" (at the expense of some SMPS hash noise).  :)
Posted: 08:00am 30 Apr 2023
Thanks folks, it looks like the GPS is somewhat functional at 3.3V, but it takes much longer to get an initial lock.
If that doesn't work out then I already have ten of those modules from an earlier AliExpress spending spree where I came across then in passing and thought they sounded useful.
Turbo46
Posted: 08:06am 30 Apr 2023
You may need level shifters in that case?
Posted: 08:09am 30 Apr 2023
  Mixtel90 said  A diode pump fed from a PWM pin will get 5V (or even -5V!) easily, but with the low current available from the RP2040 there will be very little current available. Probably only a couple of mA. Put a paralleled up hex inverter chip in as a buffer and it may be fine. However, the PCBs thhat Tom has found work out *way* cheaper and smaller than a cobbled together system and will very likely "just work" (at the expense of some SMPS hash noise).  :)
Typically GPS modules are power hungry. 40mA is not strange. Try your phone, disable location, and you get 10-20% more time from the battery.
Pumpin from even a hex inverter is inadequate. Toms prposal is the best, unless 3.7V from the battery is sufficient for this particular module.
3.7v not 3.3v....
Edited 2023-04-30 18:10 by Volhout
Posted: 09:57am 30 Apr 2023
I've never used a GPS module  - and the one in my phone got switched off when I first got it. :)
Quazee137
Posted: 10:01am 30 Apr 2023
I am using a boost but its from 5 to 24. The chip has an enable pin so its
easy to turn on/off.
See if the GPS has a enable pin to turn it on/off else add a transistor.
Quazee137
