Forum Index : Microcontroller and PC projects : Need Help. How to compile the picomite source under win 10
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
HI, Has any other user of this forum been able to achieve success in compiling the PicoMite source code from matherp? Iam using Win10 but get no success. i installed pico visual studio visual studio 2022 python 3.10 git cmake 3.26 gcc-arm-none-eabi-10-2020-q4-major-win32 ! maybe this is the fault, matherp use GCC 12.2.1 arm-none-eabi after some frustrating days to try everthing working i get these erroe code [proc] The command: "C:\Pico\Pico SDK v1.5.0\cmake\bin\cmake.EXE" --no-warn-unused-cli -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=TRUE -DCMAKE_BUILD_TYPE:STRING=Debug "-DCMAKE_C_COMPILER:FILEPATH=C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-gcc.exe" "-DCMAKE_CXX_COMPILER:FILEPATH=C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-g++.exe" "-SC:/pico mite/PicoMite-main/PicoMite" "-Bc:/pico mite/PicoMite-main/PicoMite/build" -G "nmake makefiles" exited with code: 1 if anyone can help i will setup a Teamviewer connection. Thanks a lot Plasma |
I used this on W11: https://github.com/raspberrypi/pico-setup-windows and then installed GCC 12.2.1 and altered things to suit. Removing my failed attempts fully was the hard part. Note I know nothing abut all these mysterious tool chains so I am the last person to offer sensible help. I have managed the standard picomite. Not the WEB or VGA but will try the VGA soon. Jim edit: I 'think' the only change needed once I had cleared out the old installs was to edit "C:\Users\Jim\AppData\Local\CMakeTools\cmake-tools-kits.json" to point to the 12.2 version. Edited 2023-04-28 08:22 by TassyJim VK7JH MMedit |
HI , thanks Tassyjim , can you show me a link to the gcc 12.2.1? i will setup a new virtual maschine , because so many failed tests here also. i fear i have broken my windows thx a lot again Plasma |
https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads Jim VK7JH MMedit |
