Local Time 11:03 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: Floating Point Quirk?
DrifterNL
Posted: 09:54am 21 Apr 2023
Hi all,
I've been trying to wrap my head around this.
Is this one of those floating point quirks, is my thinking wrong or am I getting something mixed up?:
* PicoMite Version 5.0706
Dim a = 100
Dim b = 0
Dim c = 0.1
start:
Print b
If b = a Then GoTo equ
If b > a Then GoTo gre
If b < a Then Inc b,c
GoTo start
equ:
Print "equal"
Print "a= " a
Print "b= " b
End
gre:
Print "greater than"
Print "a= " a
Print "b= " b
End
If I run the program as is I get:
greater than
a= 100
b= 100.1
b = a isn't recognized?
When I change c to 0.2 I get:
greater than
a= 100
b= 100
b is greater then a?
When I change c to 0.25 I get:
equal
a= 100
b= 100
b = a is recognized, seems to work
Edited 2023-04-21 20:00 by DrifterNL
Floating Point Keeps Sinking Me!
Back To Integer So I Don't Get Injured.
Posted: 10:06am 21 Apr 2023
Option default float ?
Yes, this is strange. As if behind the comma, there is a difference that is not printed on screen.
Edited 2023-04-21 20:13 by Volhout
Posted: 10:12am 21 Apr 2023
This is standard floating point behaviour 0.1 cannot be exactly expressed as a float therefore 1000*0.1 will not equal 100. In general you should never test for equality of floats after any arithmetic but must allow a small delta e.g.
if abs(a-b)<0.000000001
DrifterNL
Posted: 10:28am 21 Apr 2023
Thanks for the info!
Darn, floating point got me again.
Posted: 10:46am 21 Apr 2023
Think I might have mentioned this before, Years ago HiSoft BASIC had the == operator which meant "roughly equal to" precisely because of FP wrinkles like this
so
IF 1000*0.1 == 100
would be true
no idea how the thresholds were set up
As a callow youth taking my first steps in this stuff professionally, It was always drummed into us to "get things into integer ASAP"
