Local Time 02:26 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Pico clone with SD on board
Pilot352
Posted: 12:38pm 20 Apr 2023
Maybe this has been noted before but it looks cool...
https://www.youtube.com/watch?v=ma40w3_8dtg
8M of RAM and the SD card is mounted on the same footprint as a Pico. Same pin-out as well. Not available yet in the states but interesting.
-Tim
Posted: 02:21pm 20 Apr 2023
It would be interesting to know if it has slower memory like the YD-RP2040.
Edited 2023-04-21 00:22 by Mixtel90
Posted: 04:59pm 20 Apr 2023
Where to buy one? looks brill. what's lei as money? does mmbasic work?
Again looks good but where to buy if it works with mmbasic
Posted: 05:26pm 20 Apr 2023
Buy one and test it for us. Be sure to let us know how you get on. :)
You can probably import one from Romania (with 22UKP postage costs, then customs duty, and VAT as well) if you contact them. (If they'll even post to the UK). :)
Posted: 05:49pm 20 Apr 2023
@Mixtel90 get your point, not £5 but...
Pilot352
Posted: 06:02pm 20 Apr 2023
More info....
https://ardushop.ro/en/home/2652-marble-pico.html
Like I said, so far, it doesn't ship to the US. however, one of my co-workers is Romanian and is trying to get a few for "evaluation" :)
-Tim
cdeagle
Posted: 08:29am 21 Apr 2023
Here are links to two boards with Micro SD capability.
StackyPi from SB Components
https://shop.sb-components.co.uk/products/stackypi
I'm using these options with the StackyPi
OPTION FLASH SIZE 8388608
OPTION SDCARD GP9
Adafruit PiCowbell Adalogger for Pico - MicroSD, RTC & STEMMA QT
https://www.adafruit.com/product/5703
I don't think MMBASIC supports the RTC on the Adafruit board.
Posted: 09:34am 21 Apr 2023
I'm now wary of the clone boards with extra things on them. Every extra item introduces another layer of incompatibility with the standard unless you defeat it, in which case you've bought something you don't need. An *identical* Pico design, just with more flash, is probably the best thing to get.
pwillard
Posted: 12:38pm 24 Apr 2023
Unless some big retail company like Sparkfun, Microcenter, or Adafruit in the US starts to carry these, the US market is just not able to adopt these. A bummer.
darthvader
Posted: 10:30am 29 Apr 2023
@Mixtel90
  Quote  It would be interesting to know if it has slower memory like the YD-RP2040
Ordered last Sunday , I get them today , the memory chip is a 133mhz 25Q64JVSIQ
@stanleyella
  Quote  Where to buy one?
Ardushop
  Quote  what's lei as money?
It's Romanian money , 1 lei = 0.2€
I get 6 of them , the price are :
142.66 lei for 6 marble pico
109.78 lei Shipping to France
40.31 lei as Taxes
Total of 252.44 lei , that is approx 50.71€
Now i need to find some time to test them
Cheers ...
andreas
Posted: 05:03pm 30 Apr 2023
May I add the "Maker Pi Pico" board ;-)
Just discovered & ordered it (rasppishop.de € 13,99 + € 4,99 S&H)- so I can't tell any more, but the features seem to be interesting.
and there is a version with socket:
-andreas
Edited 2023-05-01 03:25 by andreas
Posted: 05:11pm 30 Apr 2023
I think matherp has one of those, Andreas. :)
andreas
Posted: 05:27pm 30 Apr 2023
  Mixtel90 said  I think matherp has one of those, Andreas. :)
Thanks for info!
Then I suppose PicoMite/WebMite runs on it or is the fixed assignments of some pins to external devices a problem?
Posted: 05:31pm 30 Apr 2023
No idea. I think he found a couple of problems with it, but I've no idea if he fixed them.
Posted: 05:40pm 30 Apr 2023
It is perfectly useful as a breakout. The only issue I remember was that trying to use the buzzer reset the Pico
andreas
Posted: 06:36pm 30 Apr 2023
  matherp said  It is perfectly useful as a breakout. The only issue I remember was that trying to use the buzzer reset the Pico
I can't wait to get it
-anreas
andreas
Posted: 06:48pm 30 Apr 2023
  matherp said  The only issue I remember was that trying to use the buzzer reset the Pico
May be there was a shortcut or inductive spikes because the piezo is in the near of the reset button and connection between the reset button and the run header runs under the buzzer from top to left side. May be this connection works like an "antenna".
-andreas
JanVolk
Posted: 08:59pm 30 Apr 2023
This was my first Raspberry Pi Pico board and MAKER PI PICO board and works perfectly to experiment with and has plenty of spare parts on it all supported by PicoMite Basic.
I modified it a bit by interrupting the LED voltage on the bottom by interrupting the relevant pad. Now it appears that the pins of the external DEBUG are not connected by default, so I use the SWCLK pin to connect to the 3V3 of the LEDs GP14 and GP15 on top of the PCB with a thin insulated wire via the free path.
This way I can make a jumper link on top of the print to provide the LEDs with 3V3 power or not. And insulate the bottom of the interruption with a drop of second glue.
Good luck.
JanVolk
Posted: 09:19pm 30 Apr 2023
Please note this only applies to the MAKER PI PICO board with separate Raspberry Pi Pico.
I also placed nylon spacers against short circuits and mounted a DS3231 RTC print via the nylon bushes and support bushes on the bottom so that date and time can be kept on the SD card.
Good luck
Pilot352
Posted: 11:47am 08 Jun 2023
As I mentioned in an earlier post, I have a friend from Romania who said they would see if they can get a few. Well, I just got four of them yesterday and I will be evaluating them in the next week or so. Stay tuned...
-Pilot
