Local Time 11:02 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : call FLASH CHAIN n allways return error message
StefanDraeger
Posted: 09:45am 01 Apr 2023
Hello,
I like to chain two programs in my PicoMite.
The first one is only
a = 1
b = 2
PRINT a + b
The second one is
c = 5
d = 7
PRINT a + b + c + d
Now I've read at the documentation the command FLASH CHAIN 1 would run the first code and with FLASH RUN 2 I can run the second code.
But i allways get an error.
https://i.imgur.com/EHBi9dA.png
https://i.imgur.com/reE2Yrx.png
What did I do wrong?
Turbo46
Posted: 09:53am 01 Apr 2023
The error message is telling you:
"Invalid at command prompt"
It should be the last line of your program.
StefanDraeger
Posted: 09:56am 01 Apr 2023
Okay, now I've got solve it by my selfe.
Sorry.
The solution is to run flash chain at the end of the first program.
Like:
a = 1
b = 2
PRINT a + b
flash chain 2
StefanDraeger
  Turbo46 said  The error message is telling you:
Thanks thats right!
Posted: 10:17am 01 Apr 2023
don't get hung up on where the CHAIN command goes- it doesn't have to be at the end, it could be the result of an IF for example.
It can be anywhere in your program and it means "abandon what you are running right now, load this other program and continue"
but the point is; if you aren't running a program, there is nothing to abandon - sooooo it can only be used as part of a program which makes it "Invalid at command prompt" (because if you are at the command prompt, there is no program running)
Edited 2023-04-01 20:24 by CaptainBoing
Posted: 11:04am 01 Apr 2023
There's a slight gotcha with CHAIN that can catch people out. It's not like a GOSUB or CALL, it behaves like RUN but doesn't clear the variables. The CHAINed program always begins running with the first line of the program. Likewise, if you CHAIN back to the original program tht will also run from it's first statement, not from the one after the original CHAIN command.
It's just something to be aware of.
