Local Time 11:03 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : sd cards
Posted: 11:55pm 30 Mar 2023
Posted: 12:09am 31 Mar 2023
oops. in the non-vga manual it says
SD Cards
An SD Card socket can be connected to the PicoMite and accessed as drive B:.
but using an ili9341 sd card slot I had to use play wav "a:/t1" to make it work.
lot of head scratching to figure file$ is "a:/file".
playing a wav file is impressive.
Posted: 07:22am 31 Mar 2023
Looks like drive A should be the flash file system and B the SD card, so:
1. is your a:/file actually on the SD card?
2. are you using an old MMBasic version which doesn't support the documented drives?
Posted: 01:41pm 31 Mar 2023
Thanks @JohnS
1. there's t1.wav on the sd card
2. I'm using v05.07.06 non vga firmware
I'm using the ili9341 circuit in the latest manual.
play wav "a:/t1" works
play wav "b:/t1" gives error "no volume space"
