Local Time 13:03 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : out of memory error
Posted: 04:02pm 23 Mar 2023
Hi, I tried bresenham line code,not basic but think I converted it but gives out of memory error.
I want to plot the x,y co-ordinates from x1,y1 to x2,y2 but use for sprite co-ords
and move each loop or slower.
OPTION EXPLICIT
OPTION DEFAULT NONE
OPTION DEFAULT INTEGER
dim dy, dx, incrE, incrNE, d, x, y
dim x1,x0,y1,y0
cls rgb(black)
'The procedure takes the start points (x0,y0) and end points(x1,y1) of the line as arguments.
'draw_line (x0,y0,x1,y1)
x0=160:y0=200:x1=50:y1=40 'test line
'The internal variables dy, dx, incrE, incrNE, d, x, y. dx is the change in x, dy the change in y. d determines if the next pixel is on the same line or rises one. The variables incrE and incrNE are used to change the value of d. x and y are the point to be plotted, initially the first point given.
 dx = x1 - x0
 dy = y1 - y0
 d = 2 * dy - dx
 incrE = 2*dy
 incrNE = 2*(dy - dx)
 x = x0
 y = y0
 pixel (x,y,rgb(yellow))
'The while loop does the work. x is incremented each time through the loop. Because the plot happens at the end of the loop, x is incremented before each plot.
do while (x < x1)
'If d is less than one d is increased by incrE, y remains the same, and x is incremented.
 if (d <= 0)
   d=d+incrE
   x=x+1
'Otherwise d is increased by incrNE, and both x and y are incremented.
 else
   d=d+incrNE
   x=x+1
   y=y+1
 endif
 pixel(x,y,rgb(yellow))
loop
Posted: 04:17pm 23 Mar 2023
if there's a missile command game in mmbasic the slow line code would be there.
Posted: 04:24pm 23 Mar 2023
  stanleyella said  if there's a missile command game in mmbasic the slow line code would be there.
Yes for the CMM2, by @Vegipete, but it may be unreadable because the BASIC was "compressed" to meet the size requisites of the 2021 Programming Challenge: https://multimite.strongedge.net/greenhills.html
Posted: 05:57pm 23 Mar 2023
Not sure if that was your actual code that you posted, but there is an errant '{' after the DO WHILE. Possibly the problem is an incorrectly reported syntax error?
Also don't forget you can use the INC command for incrementing and decrementing variables.
Edited 2023-03-24 03:57 by thwill
Posted: 06:22pm 23 Mar 2023
There's a less compressed version of VegiPete's In Defense of the Green Hills for the F4 here
I'm not sure how successfully it could be made to run on the PicoMite--it was slow on the Armmite F4--but the firmware has been tweaked considerably since then. For speed, it would need VGA or an SSD1963 (Mick has a PicoMite design). The algorithm for slow line draw from there should be fine.
