Local Time 14:18 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : date$() time$() trailing chars?
ville56
Posted: 06:34pm 17 Mar 2023
just encountered trailing chars in date$() and time$() functions. E.g.
print time$(now) returns "19:28:07 0" and
print date$(now) returns "17-03-21 0"
datetime$ seems to be not affected.
This bug(?) applies to Pico and PicoWeb, both latest versions.
Reagrds,
Gerald
73 de OE1HGA, Gerald
twofingers
Posted: 06:58pm 17 Mar 2023
Hi Gerald,
I think "now" is interpreted as a regular variable.
I.e. you get the result of Date$ plus the variable "now", which in your case is "0".
Try your entries after "Option explicit".
Edited 2023-03-18 05:03 by twofingers
ville56
Posted: 07:14pm 17 Mar 2023
thanks twofingers,
you are absolutely right. Overlooked that there are no arguments with that functions. Retrospectively I would have expected a syntax error, but be it as it is.
tnx agn,
Gerald
toml_12953
Posted: 04:04am 18 Mar 2023
  ville56 said  thanks twofingers,
tnx agn,
Gerald
When someone asked Yogi Berra*, "Yogi, what time is it?"
He answered, "You mean now?"
* Yogi was an American baseball player known for his offbeat speech
Posted: 08:07am 18 Mar 2023
  ville56 said  Retrospectively I would have expected a syntax error
This illustrates one of the problems with parsing expressions.
Date$ is a valid function that returns the date.  (now) is a perfectly OK (if odd) expression which resolves to the variable now which defaults to zero.  Put the two together and you have a completely correct BASIC expression which does not do what you expected.
