Local Time 15:16 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM1(PIC32MX150) firmware...
Posted: 06:29am 17 Mar 2023
What was the most up to date firmware release for the MM1 series of chips?
I have one here, running Version 4.0504
I know the 150's are basically not supported anymore/EOL, but I have a project(Sever Shutdown Timer) and it only needs very simple code and the earlier MM1 based on the 150 chip is fine, and I have a few of these spare, so a perfect chance to use them in this day of chip shortages.
Thanks for any comments.
Posted: 08:20am 17 Mar 2023
Do you mean the PIC32MX150F128B? I can't find it at all on Geoff's site.
I can only find the PIC32MX170F256B.
Unfortunately, on many pages Geoff doesn't explicitly state which CPU(s) is/are involved.
I _think_ you may want "lite" from here
Posted: 08:43am 17 Mar 2023
It is still on my website:
The direct link is: https://geoffg.net/Downloads/Micromite/Micromite_Original.zip
Posted: 09:02am 17 Mar 2023
Aha! I used PIC32MX150F128B (i.e. included the B) and it's not found by a web search :(
Some of that "AI" in ChatGPT is needed!!
It really should NOT matter if the B is there or not (unless the word is quoted, but it wasn't).
The phrase "standard Micromite" kept cropping up, too, without mentioning which chip(s) (other than pin count).
Edited 2023-03-17 19:05 by JohnS
Posted: 09:27am 17 Mar 2023
There are two versions of the firmware for the B and D versions of the chip.  Which is why I did not specify the exact variant.
But no matter.  It is always hard searching for things like that - I have sometimes spent hours looking for something on the web that I saw just the day previously.
Posted: 09:39am 17 Mar 2023
Sorry I (& search) missed it, though!
I know what you mean... on a good day it's still in search History :)
Posted: 02:24am 18 Mar 2023
Thanks very much.
The chips I have here are 150F128B.
I should have looked on Geoff's site, but I figured that as it is essentially discontinued and EOL, it probably is not up on his site anymore - assumptions being the mother of all.......
I would not use this older FW normally, but I need to build another server shutdown timer, and I still have about ten 150's I probably will never use, and the original project used the 150 chip, so...
Posted: 07:44am 18 Mar 2023
Makes sense to use them - and the PIC32 is a great chip. Good I/O & robust.
I wish Microchip had improved it - more memory (& speed). Maybe added a 2nd core.
Posted: 08:08am 18 Mar 2023
Well, the 170 added more memory, but yeah- I agree with you.
I expect it was a case of fundamental economics vs demand.
