Forum Index : Microcontroller and PC projects : Forum Log Out
Every time I visit this site I have to login again, I have ticked the 'remember me' box, anyone else finding this. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418 |
That has never worked for me. I copy & paste from a text file to save typing PW every time. |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1159 |
Only when using two different machines. F4 H7FotSF4xGT |
Lads, That used to happen to me very often and YES it was when I changed from my iPad to PC or vice versa but it doesn’t seem to happen now. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
No problems here. Occasionally, when FireFox does an update, I might have to log in again but FF is set to remember the details so only one extra click. Jim VK7JH MMedit |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 421 |
No problems here. /Pluto |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
I have also no problems... Even with privacy badger and adblocker engaged. Hm... Greetings Daniel |
No problems with having to log in again--but I never close the window that is open to thebackshed, and never power off unless Windows Update forces me to. If I open a new window to search for something, it still knows who I am. Do you have a setting for no cookies? That might cause what you are seeing. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I stay logged in all the time - no problems. I agree with lizby - check your cookie settings. Smoke makes things work. When the smoke gets out, it stops! |
you have possibly told your browser to forget all cookies at the end of each session. see below for where the checkbox for this in firefox: ![]() cheers, rob :-) |
I use Chrome and I did just recently set it to delete browsing history on exit. I will look into it. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Works fine with iPhone, but not with Firefox under win10 Plasma |
Works for me with firefox (under Linux, but that is likley irrelevant). John |
