Local Time 14:17 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TeamGroup 512GB M.2 SATA SSD for sixty bucks.....
Posted: 07:10am 12 Mar 2023
It never ceases to amaze me, how cheap storage keeps getting.
Now, 512GB is not that much these days, and SATA on M.2 is lower-spec then NVMe drives in M.2, but.....
In my case, I am rebuilding my FM radio station computer, and elected to use a mini-PC with an M.2 slot, and install the OS and all the music to one small M.2 card.
Sixty Buck 512GB M.2 SSD...
NZ$61.30, or US$37.58 in yank dollars.
This SSD is an underperformer, generally speaking, but for the purposes of what I wanted - a system running ONLY Windoze 8.1 Pro, the player software(Zara Radio), and an audio processing engine(Breakaway Audio Enhancer) - this thing is perfect.
Certainly not the best performer in the world, but for the price, I can install the system and all the music on the one small M.2 stick.
....all for sixty bucks new.
Pretty amazing, even if this drive is a bit slow by modern M.2 standards.(speed is not required for music playback)
Martin H.
Posted: 09:24am 12 Mar 2023
Germany ... ~25 €
'no comment
mclout999
Posted: 04:04pm 13 Mar 2023
That is a SATA Drive and VERY SLOW.  NVME PCI are much faster(3000 to 7000 instead of 600) If you have NVMe PCI use it. The WD drive is 4000 for $35 https://www.amazon.com/WD_BLACK-250GB-SN770-Internal-Gaming/dp/B09QVP977F/ref=sr_1_1_sspa?crid=24EC4G0M4X28U&keywords=nvme+ssd+500gb&qid=1678722979&sprefix=nvme+ssd+%2Caps%2C114&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzRDk3MllTUE1OTVEwJmVuY3J5cHRlZElkPUEwMDAyMjk3RUIxVDVEUUdLVDhXJmVuY3J5cHRlZEFkSWQ9QTA5OTY0OTlDWDJVNU4zTlVWWUMmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Strider
Posted: 09:58pm 13 Mar 2023
$25 here in the US as well.
https://www.amazon.com/TEAMGROUP-512GB-Solid-State-Drive/dp/B07H21182F/
I have the 1TB version in one of my systems, good drive! I also use TG's RAM and SATA SSDs, have always had good luck with them.
A classic geek! Expert at nothing, professional hobbyist! My Projects  My Social
Posted: 11:33pm 13 Mar 2023
@ mclout999 - Yes, I know it is slow and SATA on M.2 and not NVMe - see my orignal post where I mention that myself.
I'm not interested in lightning speed, as this machine is just a music player for my FM radio station.  Reading music data files can be done with the slowest of the slow drives without any issue.
