Local Time 16:44 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA dead after set to 378MHz
Amnesie
Posted: 02:23pm 08 Mar 2023
Hello,
after trying the latest version of picoMiteVGA (2023-03-07_001019_PicoMiteVGA)
everything worked fine, but right after setting
OPTION CPUSPEED 378000
the pico is dead, no blinkin onboard led and no connection via TeraTerm. I re-flashed the firmware to the official release on the geoff website and it is still dead.
And yes, I looked in the manual on page 10 which suggest to clear the flash, but the link in the manual is broken (https://geoffg.net/Downloads/picomite/Clear_Flash.uf2)
In the offical release on the geoff website is no clear flash firmware in the archieve...
Would anybody please provide me a link to it?
Greetings
Daniel
twofingers
Posted: 02:28pm 08 Mar 2023
Hi Daniel
2021-12-17_025627_Clear_flash.zip
Michael
Amnesie
Posted: 02:56pm 08 Mar 2023
Thank you Michael, that worked.
This is the first pico on which 378Mhz is not working... Flashed about 6 or so.
Greetings
Daniel
Posted: 03:01pm 08 Mar 2023
It's *way* beyond specification for the RP2040. Don't be surprised if you get reliability issues at some point even if they appear to be working.
Amnesie
Posted: 03:10pm 08 Mar 2023
Hello Mick!
You are right, I was not even expecting to go this far but since it worked on all my previous picos I thought: "why not?".
Now I rather stick to 252000 (this works on this very pico!). Even 252Mhz is a HUGE improvement to the standard cpu speed.
Greetings
Daniel
Plasmamac
Posted: 08:26pm 08 Mar 2023
I flashed 4 picos and only one works with 378 MHZ. Sometimes
Plasma
Amnesie
Posted: 09:17pm 08 Mar 2023
I was curious and tested all my available picos and came up with:
15 tested in total, two of them were not able to clock as high as 378Mhz but all of them took the 252Mhz.
So I think we should consider 378Mhz as a nice option if it works, but not think that things run perfect. I rather stick to 252Mhz :)
Greetings
Daniel
Edited 2023-03-09 07:20 by Amnesie
