Local Time 17:21 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD Module DEM16217
asknik2022
Posted: 04:23pm 07 Mar 2023
Hi
Does anyone know if it is possible to connect this LCD Panel to a Micromite or picomite?
Spec Below
DEM 16217 SYH-PY
LCD dot matrix modules
• dot matrix modules with 2 lines and 16 characters
​• high contrast LCD-STN display
• LED backlight
• characters: black
• by Display Elektronik
• interface for 4- or 8-Bit data bus
Posted: 04:27pm 07 Mar 2023
look for BITBANG LCD in the manual (special device support and the command list). Assuming the controller is standard then should work
Posted: 04:29pm 07 Mar 2023
Should be OK. There's a diagram in both the manuals showing how to do it. It's a generic LCD display, so look under "Special Device Support". It works in 4-bit mode.
