Local Time 14:17 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Selling Colormax2
atmega8
Posted: 03:33pm 07 Mar 2023
Hello,
is anyone interested in buying a original colormax2 from circuitgizmos?
homa
Posted: 09:03pm 08 Mar 2023
Hallo,
warum gibst Du den ab? Und welche Preisvorstellung hast Du?
Versand wäre auch in Deutschland.
Hello,
why are you selling it? And what price do you have in mind?
Shipping would also be in Germany.
LG Matthias
mclout999
Posted: 12:27am 09 Mar 2023
The picture looks like a CMM1, not a CMM2 !?
Turbo46
Posted: 03:41am 09 Mar 2023
It is a CMM1. The name is confusing.
Posted: 04:11am 09 Mar 2023
Circuitgizmo named his version of the CMM1 before the CMM2 was in the pipeline.
It's an unfortunate similarity but on the bright side, the CMM1 is still a magnificent beast.
Posted: 08:46am 09 Mar 2023
Hi Jim,
Yes, the CMM1 is a very nice and reliable platform.
Used it a lot.
The only drawback is that the MMBasic is somewhat older (4.x.x ?) so it does not benefit from the latest features Peter added in 5.x.x.
Geoff once talked about doing one upgrade to the 5.x series, but as I understand the development environment for the older chip cannot handle the newer source code. Anyway, given the CMM2 exists, the pressure will be more on CMM2.
atmega8
Posted: 01:19pm 09 Mar 2023
@Matthias,
have send you a PM to the Forum Postbox.
BG
homa
Posted: 09:41pm 09 Mar 2023
@atmega8
homa
Posted: 08:47pm 11 Mar 2023
Thank you, it has arrived. I have tried to answer ... but still do not quite see through this PM stuff in the function. I no longer see my answer myself?!
atmega8
Posted: 10:53pm 11 Mar 2023
  homa said  Thank you, it has arrived. I have tried to answer ... but still do not quite see through this PM stuff in the function. I no longer see my answer myself?!
Same to me.
This Forum Software is a Pain in the…..
Posted: 11:05pm 11 Mar 2023
PM's stay in your outbox till the person receiving it reads it - and deletes it.  If the receiver deletes the message, you lose your copy of it from your outbox.
From the PM outbox page: "Outbox. Messages will stay in your outbox until the recipient deletes it."
If the receiver reads it, but does not delete it from THEIR inbox, it will stay in your outbox.
If the receiver reads it, then deletes the message from THEIR inbox, it will vanish from your outbox.
The PM pages are not an email server, and are designed for very limited PM'ing between members.  One way to control the number of messages the server has to keep track of, is this concept.  YOU have control over your INBOX, but the receiver controls if messages stay in your OUTBOX.
It seems like a strange idea at first glace, but it makes the messages self-regulating.  As your inbox grows bigger to the point you have to delete messages in your inbox, those messages sent from member X are automatically deleted from member X's outbox, freeing up message space on BOTH accounts.
It means that the server cannot become overloaded with thousands of messages over time that are never deleted by the members.
If you need to keep a copy of anything in your outbox, you should print out a copy on paper, as messages in your outbox can be deleted at any time without notice.
homa
Posted: 09:49pm 14 Mar 2023
@Grogster: Thanks for the explanation. It was only at second glance that I noticed the distinction between Inbox Outbox and New Message in the upper right corner. I also found it strange that the complete message is contained in the reply field.
But now that i have understood it once, it is so far clear.
