Local Time 16:48 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Editor-Probems with PicoMiteVGAV5.07.07b19
Erik008
Posted: 05:32am 07 Mar 2023
Hello all,
I recently started using PicoMite with version PicoMiteVGAV5.07.07b19 and I am having problems with the editor. So I write a program, which everything works wonderfully. For example, if I want to insert a new line, I move the cursor to the desired line, press return, and then insert something new. All other lines move down to make room. But now when I insert something new, those lines that moved down are no longer visible.
Does anyone know this problem? Or is it a feature?
Greetings, Erik
Martin H.
Posted: 06:45am 07 Mar 2023
this problem is solved in next Versions:
See
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15582
Edited 2023-03-07 16:45 by Martin H.
'no comment
Erik008
Posted: 08:58am 07 Mar 2023
Great. Thanks for the information.
Erik
