Local Time 15:58 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite Sd card
Plasmamac
Posted: 01:56pm 06 Mar 2023
Hi , maybe i read it anywhere but forget about because the stroke end Oktober, what size can the picomite handle , what Format should i use? If i put my 16GB sd card in the card is empty even if i put some files before.
Thx
Plasma
Martin H.
Posted: 02:02pm 06 Mar 2023
I have a 16 GB Micro SD with ... Fat32 (i think)..
I formated it in windows and it works.
'no comment
Posted: 02:27pm 06 Mar 2023
It will work with up to 32GB cards formatted to FAT16 or FAT32.
It uses SPI protocol so all types (Class 4,0,UHS- etc.) are supported.
Plasmamac
Posted: 06:54pm 06 Mar 2023
My sd card is empty after inserting into the Picomite 🥴
If i eject it the firmware shows the warning. I use the standard option for gpio sd card.
What’s wrong?
Plasma
Posted: 07:22pm 06 Mar 2023
Are you looking at the correct drive? SDcard is DRIVE "B:"
type
B:
Files
Posted: 11:52pm 06 Mar 2023
Is your card formatted in NTFS?
The PM won't like the taste of an NTFS card.
Posted: 12:45am 07 Mar 2023
Are you using an SD module with level shifter and regulator ICs on it? They can be a problem on a 3V3 system. Check that you have 3V3 on the SD socket supply pin.
Mark
Posted: 09:16pm 07 Mar 2023
Following up on phil99.
While SD cards are designed to work on 3V3, many of the SDCard adapaters out there are designed to work with 5V microcontrollers, such as the Arduino.  As such, they have a level shifter that takes 5V and converts it to 3V3 volts. Since the Pico provides 3V3, if you apply that to the 5V input, the card won't work, or won't work reliably. You need to carefully read the card's documentation to see if it wants 3V3 or 5V. If you are powering your Pico with USB and the card wants 5V, you can power it from the Pico's VBUS line (which is 5V).
Alternatively, other than a possible level converter, all the adapters just provide contacts for the card, there's no other circuitry needed. You can solder wires from the GPIO pins on the Pico directly to the terminals of the SD card. If you have a microSD card with a full size card adapter, solder the wires directly to the terminals on the adapter. That way you have an almost "free" microSD card slot.
Mark
Posted: 09:25pm 07 Mar 2023
" you can power it from the Pico's VBUS line (which is 5V)."
That will give the correct voltages on the SD card but may put 5V on the Pico pins. The Pico I/O pins must not exceed 3.6V
Posted: 09:39pm 07 Mar 2023
Basically, don't use adapters that have a voltage reg on them. Some will work, some won't. Some will be fine powered from 5V, others have pull-up resistors to 5V and you will be relying on the static protection diodes of the PicoMite to prevent damage. And there may not be any of those diodes (I think the Datasheet only mentions them for ADC inputs).
There are some adapter modules that have simple pull-ups to 3V3 and a decoupling capacitor. Those are fine, I use them myself. There is no voltage reg. Look for a design where the socket is mounted "upside down" on the board.
Plasmamac
Posted: 10:23pm 10 Mar 2023
The New Sd card works fine. Thx for the help
Plasma
