Forum Index : Microcontroller and PC projects : PicoMiteWeb alphas a21+ NTP rework
| Page 1 of 2 |
PicoMiteWeb V5.07.07a21 PicoMiteWebV5.07.07a21.zip Fixes bug in TEMPR command and function at standard CPU speeds I've re-engineered WEB NTP as many of you seem to be having problems. You can now also select the ntp server WEB NTP [timeoffset [, ntpserver$]] e.g. web ntp 0,"uk.pool.ntp.org" Note, if you want to specify the ntp server you must specify a timeoffset (standard limitation of MMBasic). The server can be specified either as a text or numerical IP address e.g. "uk.pool.ntp.org" or "217.114.59.3" This version also has a significant internal change to memory utilisation and now has 84Kb available for programs. It is also about 20% faster than before. Usual flash/option warning WEB MQTT will now allow 8883 addresses and use TLS. HOWEVER, it does not support SSL over TLS which commercial MQTT servers may require. I don't think this will ever be possible given the memory limitations of the RP2040. Please report any issues Edited 2023-03-05 20:53 by matherp |
Thanks for the NTP work. I have only had a missed read once in a few hundred requests but I am pleased that I will be able to use my own GPS derived NTP server. Jim VK7JH MMedit |
| Michal Senior Member Joined: 02/02/2022 Location: PolandPosts: 125 |
Hi @matherp Trying to receive a message from PicoMiteWebV5.07.07a21 on a test MTQQ Server/Client compiled in Delphi11-Win32: MQTTSC (may be needed libssl-1_1.dll, libcrypto-1_1.dll. Login: admin/password) And on the Pico client I get an error and on the server a quick instant disconnection after logging in. What is wrong. Michal |
This server seems to work in both SSL and non-SSL modes. Michal |
I just use the Mosquitto server for test. Easy to install on windows and works perfectly. There are videos on youtube explaining how to get it up and running |
Oops. Sorry. MQTTSC1 I added the missing *.pem files. Michal |
Sorry, but life is too short to try and diagnose every MQTT broker variant. It is down to you to diagnose. |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 733 |
Peter, thank you! Now my own NTP server works :-) PicoMiteWeb MMBasic Version 5.07.07a21 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather Connecting to WiFi... Connected 192.168.1.133 Starting server at 192.168.1.133 on port 80 > print time$ 00:00:11 > web ntp 1,"192.168.1.1" ntp address 192.168.1.1 got ntp response: 05/03/2023 21:26:31 > option web ntp 1,"192.168.1.1" Error : Invalid Option > option ntp 1,"192.168.1.1" Error : Invalid Option > But how can I have the time automatically queried directly at startup? Matthias |
sorry - there was nonsense here Edited 2023-03-06 06:38 by homa |
sub mm.startup web ntp 1,"192.168.1.1" end sub |
| JanVolk Guru Joined: 28/01/2023 Location: NetherlandsPosts: 420 |
Peter, It now all works without problems with the DS18B20 sensor and has worked for half a day without errors with PicoMiteWeb Version 5.07.07a21 and PicoMite Version 5.07.07b25. Also nice that the Web version and the other versions at Edit now show a red message "LINE IS TO LONG" which I have not noticed before what an improvement. With the Web version, after reset, PicoMiteWeb MMBasic Version 5.07.07a21. And after Option list comes the Web version PicoMite MMBasic Version 5.07.07a21. Jan |
| RonnS Senior Member Joined: 16/07/2015 Location: GermanyPosts: 123 |
Hello Peter M, first of all, thank you for your diligent work So far everything has worked for me and I haven't had any problems. for the future I ask: will it be possible to play an internet radio stream or a video stream, for example: eg PlayStream" internet address" as MP3/Stream or somthing else ? or a camera stream? just as easy as your "jokebox" the ESP32 can do that! Thank you and I really appreciate your work Ron example for an Radio stream : http://www.beatlesradio.com:8000/stream or http://81.17.57.158:24929/stream Edited 2023-03-06 09:20 by RonnS |
| aFox Senior Member Joined: 28/02/2023 Location: GermanyPosts: 110 |
PicoMiteWeb is pretty promising. Perhaps I may add another suggestion here. RFO-Basic for Android used for data transfer via WiFi/Ethernet "sockets". See https://www.tapatalk.com/groups/rfobasic/android-connection-to-pc-by-browser-t5787.html#p42289 for an example Http server. Manual RFO-Basic 1.91: https://gitlab.com/OliBasic/Main/-/blob/master/OliBasicXXIV/Documentation/RFO-Basic%20Manual%201.91%20De_Re_BASIC!.pdf Manual Appendix OliBasic 3.00+: https://www.tapatalk.com/groups/rfobasic/download/file.php?id=5677 Fork of RFO-Basic 1.91 with a lot of enhancements, OliBasic 3.00+: https://www.tapatalk.com/groups/rfobasic/olibasic-3-0-preview-t6292-s40.html#p48256 See the Socket, Http, Byte and Html commands. Maybe you get ideas, hints or something else. An option is collecting the data (maybe via device hotspot) of some Picos and its processing by a "Basic" interpreter on Android also. Gregor Edited 2023-03-07 03:30 by aFox |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 910 |
Hi all, My Pico-W is still crashing but I can't identify potential caus(es) yet (I have a test running). It crashes and prints to the console: "*** PANIC *** Out of Heap memory" BUT I have uncovered one quirk. My code (see below) checks the Pico-W's TIME$ in a DO-LOOP and at "00" seconds every 5 minutes it calls up NTP (this is a test, in real life it will be much less frequent). BUT it is called up twice in about one second. I suspect that the Pico-W's time is running a fraction slow and is seeing the same 15 minute trigger twice. The capture below illustrates it. My fix is to insert a 250ms delay before the NTP call so the Pico TIME$ has progressed to the next second and fails the "00" test. (the code below is AFTER the fix was inserted - it now appears to be working well. I am still waiting for the next *** PANIC *** attack due to causes unknown.) Any comments or suggestion? Cheers, Andrew Console capture (with A_G comments after <<): RUN Pico-W_OWeather v2 for TBS.BAS Started 01-04-2000 at 11:22:26 (local - before NTP) 02-04-2000 00:00:00 01-10-2000 00:00:00 ntp address 103.126.53.123 got ntp response: 07/03/2023 11:22:26 07-03-2023 11:22:26 . . . 11:25:00 Flag ON <<Flag is set at 11:25:00 (Pico-W TIME$), calls for NTP 02-04-2000 00:00:00 01-10-2000 00:00:00 ntp address 162.159.200.123 got ntp response: 07/03/2023 11:24:59 <<NTP responds and resets Pico-W TIME$ to 11:24:59 07-03-2023 11:24:59 11:24:59 Flag OFF <<Pico-W's TIME$ passes 11:25:00 so calls for another NTP (about 1 second after the last one) 11:25:00 Flag ON 02-04-2000 00:00:00 01-10-2000 00:00:00 ntp address 162.159.200.123 got ntp response: 07/03/2023 11:25:00 <<NTP responds and resets Pico-W's TIME$ to 11:25:00 11:25:01 Flag OFF . . . 'Pico-W_OWeather v1a for TBS.BAS OPTION EXPLICIT OPTION DEFAULT Integer dim String Version = "Pico-W_OWeather v2 for TBS.BAS" 'OPTION WIFI MySSID, MyPassword 'This OPTION is held in flash until changed or re-flashed 'OPTION WIFI "***********", "***********" Const True = 1 Const False = 0 'Flags: dim Integer Fl.NewPeriod = False DATE$ = "01-04-2000" ' Tassyjim - March 2023 DIM Integer Tzone = 10 'Jim's code adds DST when appropriate AEST (11 for DST) Print Version; " Started ";DATE$;" at "; Time$; " (local - before NTP)" Get_NTP 'Get initial values from NTP SETTICK 10000, NewTime, 1 'MAIN LOOP''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' do 'Watchdog 60000 'ZZZ leave out until code is in use if mid$(TIME$,7,2)="00" and VAL(mid$(TIME$,4,2)) Mod 5=0 and not Fl.NewPeriod Then 'A new 5 minute Fl.NewPeriod = True Timer = 0 print time$; " Flag ON" do: Loop while timer < 250 Get_NTP End If 'A new 5 min if mid$(TIME$,7,2)<> "00" and Fl.NewPeriod Then '1 second after start of the new minute print time$; " Flag OFF" Fl.NewPeriod = False End IF Loop 'main loop''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' sub NewTime print "."; 'just a heartbeat End Sub Sub Get_NTP local string TempDate, TempTime local Integer Tmp ' NTP Timeout loop by TassyJim Tmp = 0 TempDate = Date$'Trying to preserve values in case NTP fails (old values OK for now) TempTime = TIME$ DATE$ = "01-04-2000" DO ON ERROR SKIP 'web ntp 11,"uk.pool.ntp.org" WEB NTP Tzone+DST(),"au.pool.ntp.org" if MM.ERRMSG$ <> "" then print MM.ERRMSG$; " skipped" DAte$ = TempDate Time$ = TempTime Exit Do End If IF DATE$ = "01-04-2000" THEN PRINT "NTP Timed out. Tmp = ";Tmp PRINT #1, "NTP Timed out" End If INC Tmp LOOP UNTIL DATE$ <>"01-04-2000" OR Tmp > 4 'NTP automatically sets DATE$ and TIME$ If Tmp > 4 then DAte$ = TempDate print Date$; " "; Time$ End Sub 'Get_NTP FUNCTION DST() 'Ex TassyJim LOCAL integer daynumnow, aprstart, octstart, dst1, dst2 local string dateNow$ dateNow$ = DATE$ daynumnow = EPOCH(datenow$+" 00:00:00")/86400 aprstart = EPOCH("01-04-"+MID$(dateNow$,7,4)+" 00:00:00")/86400 dst1 = 3-(aprstart MOD 7) dst1 = aprstart+dst1 ' first sunday in april in current year octstart = EPOCH("01-10-"+MID$(dateNow$,7,4)+" 00:00:00")/86400 dst2 = 3-(octstart MOD 7) dst2 = octstart+ dst2 ' first sunday in october in current year PRINT DATETIME$(dst1*86400) ' for debug PRINT DATETIME$(dst2*86400) IF daynumnow < dst1 OR daynumnow >= dst2 THEN ' swap for northern hemisphere dst = 1 ELSE dst = 0 ENDIF END FUNCTION 'DST ' ' ' Edited 2023-03-07 11:36 by Andrew_G |
Andrew, I 'think' that once called, NTP will make regular calls to update time without the need for you to do anything. It just needs to be run once at the start of the program. In your Get_NTP sub, you are setting the date to 1-4-2000 and then calling DST(). This means DST will always return TRUE whatever the real date. If that first NTP call works, DST will be here to stay. You really needs to call NTP first and then if dst() is true, call NTP again with the extra hour added. I have been trying to come up with an clever way of doing all this, but I am not very clever at the best of times. dst() really only needs to be run once a day, once the program is under way. Check and if dst() is the same as yesterday, no need to change anything. Jim Edited 2023-03-07 11:56 by TassyJim VK7JH MMedit |
Thanks Jim, How do I/we confirm that NTP is a once off (just like OPTION WIFI MySSID, MyPassword ?)? (I'm happy to wait for Pater et al to chime in.) Yes my Get_NTP Sub (and most of my efforts) is clumsy - and I'm always keen to benefit from others' experience. I have learnt so much from you and TBS. DST may not be a big issue, because I suspect/hope that when Openweather outputs the weather it includes DST in its ". . . "timezone":39600, . . ." output. I can make use of that! Don't ask me how it knows that my State, and yours, has DST whereas Qld doesn't. My test code (as above) has survived longer than previous efforts with no "Panic" crashes yet - so I wonder if the frequent and almost coincident NTP calls were a problem? I'll keep testing. Cheers, Andrew |
http://www.beatlesradio.com:8000/stream or http://81.17.57.158:24929/stream For me those are MPEG so looks like you're asking for an MPEG-decoder (as well as the net stuff). John |
WEB NTP executes once only. You need to call it again if you want to update the clock. Note however the Pico xtal appears to be very stable and accurate so once a day should be enough |
Thanks Peter. Just to clarify that Jim's 'thought' of a regular update is not quite correct but that once a day is more than accurate for the simple time stamp stuff I want to use it for. I am hoping to have a Pico-W back to back with a Pico with common Vbus (5V) and Gnd and serial comms via GP00/GP01 on each. The Pico-W will do all the WWW stuff and send the data (including TIME$ etc) to the Pico. The Pico will use GUI commands to display it all and pass limited commands (eg to get Openweather NOW!) to the Pico-W. Given the sensitivities of sharing a USB hub that Jim has observed I'll need to be careful to program the two Picos separately but run them off a common supply. Well that's the plan . . . Your work on the Pico-W makes it possible. Cheers, Andrew |
| Page 1 of 2 |
