Local Time 17:21 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Olimex Pic32 T795H
IanRogers
Posted: 10:29am 03 Mar 2023
Is there a version of MM basic I could use on this beasty
It's sat doing nothing next to a spare VGA monitor.
Could any of the software's available work ( being very limited pins )
Posted: 12:40pm 03 Mar 2023
I can only find the T795. What's the H variant?
The T795 can run Duinomite Basic which was derived from MMBasic.
Also, Geoff's site may have a version of MMBasic that will run.
edit: found a pinout so I guess start checking what PIC32 (795) MMBasic wants and whether there's anything bad. The Maximite version might be worth a look.
Edited 2023-03-03 22:51 by JohnS
IanRogers
Posted: 04:34pm 03 Mar 2023
I was basing it on the UBW32 ( bitwhacker ) but that sports a 100pin device.. Same as the CMM and CMM2  but this has many many pins missing...
In fact no portA  and only a few PORTG and PORTF pins.
I already have two Maximites running.. I wanted to connect it to my spare VGA monitor
Posted: 05:14pm 03 Mar 2023
CMM2 is a very different CPU chip!
Maximite is same 64-pin 795, I believe.
CMM may be too, but I never used one.
Don't try to use 100-pin PIC32 MMBasic on 64-pin PIC32.
Edited 2023-03-04 03:38 by JohnS
