Local Time 16:48 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maybe FatFS to PicoMite?
Michal
Posted: 09:16pm 02 Mar 2023
He seems to read faster.
https://www.youtube.com/watch?v=4pcUewJgPeM
https://www.hackster.io/kamaluddinkhan/pico-supports-sd-cards-and-fatfs-5b4fb5
https://en.wikipedia.org/wiki/FatFs
Michal
Posted: 11:16pm 02 Mar 2023
I might be wrong here, but I seem to recall reading somewhere from Peter, that he used TinyFS cos anything larger gobbles up too much of the very valuable RAM in the 2040 chip.  If I am remembering that correctly, then upgrading the FS won't be something that will be happening anytime soon I would think - other then squishing any bugs found, naturally.  I expect Peter and others more in the know here with the internal details then I, will comment and tell me if that is correct or I am wrong.  But that is what I seem to remember.
Posted: 07:14am 03 Mar 2023
picomite uses Full FatFS for SD and LitteFS for flash. FatFS does not support wear levelling. LittleFS does
Michal
Posted: 07:56am 03 Mar 2023
  matherp said  picomite uses Full FatFS for SD and LitteFS for flash. FatFS does not support wear levelling. LittleFS does
Thanks, I didn't know.
Michal
