Local Time 16:48 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite DCF77 Decoder
PilotPirx
Posted: 07:18pm 01 Mar 2023
I wrote a little DCF77 decoder to get the exact time without having to type it in every time. DCF77 is a time signal transmitter near Frankfurt Main/Germany. For our Australian and American friends a bit far away, but for the Europeans great to use.
I use the Milageto DCF77 Receiving modul DCF-3850M-800 from Amazon which works fine with 3.3V and the Pico at GP1. The program writes the data to the RTC. If someone is interested, i made an 3D STL housing for the receiver.
Have fun and always the right time!
'* DCF77 Decoder   *
'* 01.03.2023 V1.0 *
'* P.Doerwald      *
Option EXPLICIT
Option DEFAULT INTEGER
Dim DCF(60)
Dim INTEGER year,month,day,dow,hour,min,sec
Dim INTEGER summer,DCFOK,DCFSTART,DCFSTEP,DCFNOERROR
Const TRUE=1
Const FALSE=0
Const HIGH=1
Const LOW=0
SetPin GP1,INTB,DCFSUB  'Clock signal at GP1
DCFSTEP=0
DCFSTART=FALSE
DCFNOERROR=FALSE
Timer =0
Print "DCF77 Decoder for MMBasic V1.0 by P.Doerwald"
Print "Waiting for sync"
Loop Until DCFOK=TRUE
DCFCALC
Loop Until DCFNOERROR=TRUE
SetPin GP1,OFF
Loop Until Timer>=2000
RTC SETTIME year,month,day,hour,min,0
RTC GETTIME
Print "DCF77 successful"
Print "Date: ",Date$
Print "Time: ",Time$
Print "Day of week:";dow
Print "Summertime:",
If summer=2 Then Print "yes" Else Print "no"
End
Sub DCFSUB  'Interrupts every edge change
If Pin(GP1)=HIGH Then
  If Timer>1700 Then 'new minute
    DCFSTART=TRUE
    DCFSTEP=0
    Print "Start"
  Timer =0
Else
  If DCFSTART=TRUE Then
    If Timer>150 Then
      DCF(DCFSTEP)=1
    Else
      If Timer>75 Then
        DCF(DCFSTEP)=0
      Else   'Error, pulse too short
        DCFSTART=FALSE
        Print "Pulse ERROR"
        DCFSTEP=0
    Inc DCFSTEP
    If DCFSTEP=59 Then DCFOK=TRUE
Sub DCFCALC   'calculating bits to time and date
Dim x,PM,PH,PD
' No Errors - parity OK?
For x=21 To 27
   PM=PM+DCF(x)
Next x
For x=29 To 34
   PH=PH+DCF(x)
Next x
For x=36 To 57
   PD=PD+DCF(x)
Next x
If ((PM And 1)=DCF(28))And((PH And 1)=DCF(35))And((PD And 1)=DCF(58)) Then
  If DCF(20)=1 Then
     DCFNOERROR=TRUE
  'ALL OK, begin calculations
  min=(DCF(25)+(DCF(26)*2)+(DCF(27)*4))*10
  min=min +DCF(21)+(DCF(22)*2)+(DCF(23)*4)+(DCF(24)*8)
  hour=(DCF(33)+(DCF(34)*2))*10
  hour=hour +DCF(29)+(DCF(30)*2)+(DCF(31)*4)+(DCF(32)*8)
  day=(DCF(40)+(DCF(41)*2))*10
  day=day +DCF(36)+(DCF(37)*2)+(DCF(38)*4)+(DCF(39)*8)
  dow=DCF(42)+(DCF(43)*2)+(DCF(44)*4)
  month=DCF(49)*10
  month=month +DCF(45)+(DCF(46)*2)+(DCF(47)*4)+(DCF(48)*8)
  year=(DCF(54)+(DCF(55)*2)+(DCF(56)*4)+(DCF(57)*8))*10
  year=year +DCF(50)+(DCF(51)*2)+(DCF(52)*4)+(DCF(53)*8)
  summer=DCF(18)+(DCF(17)*2)
homa
Posted: 07:41pm 01 Mar 2023
  PilotPirx said  If someone is interested, i made an 3D STL housing for the receiver.
Yes, I am :-)
Order for the Milageto DCF77 Receiving modul DCF-3850M-800 from Amazon is already out.
PilotPirx
Posted: 08:27pm 01 Mar 2023
  Quote  Yes, I am :-)
Great! I uploaded the files to Thingiverse. You need only VDD (3,3V), GND and Out for connecting.
Thingiverse Link
Plasmamac
Posted: 04:00pm 02 Mar 2023
Like 👍
Plasma
atmega8
Posted: 08:47pm 02 Mar 2023
Also ordered one
DrifterNL
Posted: 10:19pm 02 Mar 2023
Hello PilotPirx,
I tried your software but got the following error:
[75] Dim x,PM,PH,PD
ERROR: x already declared
After relocating the Dim x,PM,PH,PD in Sub DCFCALC to the top of your software under the other dims the software seems to work great!
The first time it synced the time was off by 10 min but running it again it got the correct time.
I am using a 5V DCF77 module through a sparkfun level converter.
Floating Point Keeps Sinking Me!
Back To Integer So I Don't Get Injured.
Posted: 12:10am 03 Mar 2023
"After relocating the Dim x,PM,PH,PD in Sub DCFCALC to the top "
Another option might instead be to change Dim to Local.
PilotPirx
Posted: 08:33am 03 Mar 2023
  Quote  The first time it synced the time was off by 10 min but running it again it got the correct time.
It is difficult to verify the time read in.
I only check the parity bits for minute, hour and date here. If an odd number of bits is wrong, it is detected, if x*2 bits flip, the error is not detected. Unfortunately, there is no checksum. The worse the signal, the more likely errors can creep in. I have also noticed that the pulse length is different for many receivers. By definition, 100ms is a 0 and 200ms is a 1.
Maybe you have an idea how to better check the plausibility of the result.
  Quote  After relocating the Dim x,PM,PH,PD in Sub DCFCALC to the top
Strange, i got no error. I´ll write them as Local.
