Local Time 18:04 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ILI8341 BREADBOARD
georgestheking
Posted: 02:17pm 24 Feb 2023
There is a new breadboard from China for the pico including I/O and a ILI9341 LCD.
I am trying to use it.
I use the last version of PICOMITE.
first line to init SPI : OPTION system spi GP10,GP11,GP8
i get "Error : DScard already configured"
Any idea ?
Best regards
Georges
Posted: 02:25pm 24 Feb 2023
OPTION RESET first?
Posted: 03:09pm 24 Feb 2023
  georgestheking said  There is a new breadboard from China for the pico including I/O and a ILI9341 LCD.
URL please
georgestheking
Posted: 04:11pm 24 Feb 2023
Here is the link :
https://fr.aliexpress.com/item/1005004743550177.html?spm=a2g0o.cart.0.0.37c5378dD9TQEh&mp=1&gatewayAdapt=glo2fra
Best regards
Georges
georgestheking
Posted: 04:14pm 24 Feb 2023
An for support
https://wiki.52pi.com/index.php?spm=a2g0o.detail.1000023.1.2da3N9ZwN9ZwZx&title=EP-0164
Best regards
Georges
Posted: 04:35pm 24 Feb 2023
I'm not certain that that display is compatible with MMBasic. Someone else may know better, but the signals are unfamiliar to me. It looks rather like a serial data input rather than SPI.
The touch device has the signals I would expect for SPI, but it has no IRQ signal.
Edited 2023-02-25 02:41 by Mixtel90
Posted: 04:40pm 24 Feb 2023
Based on a brief examination of the pinout of this board there is no way to use it in MMBasic - the wiring appears to be catastrophically stupid - different SPI for touch and the display with the display bitbanged: GP7 for WR makes no sense
Edited 2023-02-25 02:42 by matherp
Posted: 05:06pm 24 Feb 2023
Is it this
In which case is it OK?
edit: was working URL but now I'm getting Bad Gateway
pins used here
Edited 2023-02-25 03:10 by JohnS
Posted: 05:30pm 24 Feb 2023
  Quote  In which case is it OK?
See my reply above
Posted: 05:46pm 24 Feb 2023
See my reply above
I didn't understand such as "GP7 for WR makes no sense" when GPIO7 isn't called WR.
Sorry. Still mystified.
Posted: 06:44pm 24 Feb 2023
GP15 WR, GP7 SDI, still complete nonsense
Posted: 06:56pm 24 Feb 2023
Thanks.
Posted: 08:19pm 24 Feb 2023
Just a guess based on the mnemonics - it isn't SPI.
RST - reset (fair enough!)
CS - device select (probably active low)
RS - register select (to change values in them - probably active low)
WR - write - not sure of polarity
SDI - serial data IO
It's not going to work with MMBasic anyway.
