Local Time 17:22 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Are there any Word Processors written in BASIC?
Amnesie
Posted: 01:36pm 22 Feb 2023
Hello,
I am wondering if there are any Word Processors (simple) written in BASIC for the pico / maximites! I think it would be kind of interesting to see things like WordStar or WordPerfect, since it is not as distracting as a modern computer where you quickly do all other things   . I am also interested how to accomplish a simple word processor or writing program. I know in the past, there were some textviewers written in Basic ("textlook" was the name, I think).
Greetings
Daniel
atmega8
Posted: 01:49pm 22 Feb 2023
Start here:
https://github.com/Cube9999/vi
Posted: 02:04pm 22 Feb 2023
A code editor, rather than a Word Processor for the CMM2 in MMBasic by @Epsilon:
   https://github.com/epsilon537/xedit_cmm2
cosmic frog
Posted: 03:36pm 22 Feb 2023
Can't you just use the MMBASIC built in editor and save as - save "mytext.txt"
Dave.
Amnesie
Posted: 04:18pm 22 Feb 2023
Hi Dave,
that is not possible! Because in German we have "ü ä ö and ß" so if I want to write in German I have to ü = ue ä=ae and so on.. This is not a good solution.
But as far as I know there is no ü ä ö ß so I have to do my own font, right? I am still a beginner when it comes to basic. So any hint would be great.
With
  input:   a$=Inkey$
  If a$="" Then GoTo input
  Print "You pressed ";a$ " - CHR$("Asc(a$)")"
(With Keyboard set to GERMAN)
Key "ß" gives me "223"
Key "ä" = "228"
Key "Ä" = "196"
Key "ü" = "252"
Key "Ü" = "220"
Key "ö" = "246"
Key "Ö" = "214"
Is this more a question for Peter to may (?) implement those chars? Because especially when it comes to word processing it is a MUST. At this point if Peter won't implement this I have to do my own font I guess.
@ Tom
I hoped for some less complex editors to start with   . But really cool such programs exists for the maximite. I only plan to use the picoMiteVGA.
EDIT: I think I am lost, because the Inkey program above only works if sent via TeraTerm. On the PS2 Keyboard the specified Keys are not recognized at all (äüöß). Hmpf...
Greetings
Daniel
Edited 2023-02-23 02:33 by Amnesie
Posted: 04:41pm 22 Feb 2023
I don't think the "high number" characters can be used in the internal editor or in the Print command as they are used internally in the interpreter. You can use them using CHR$() and POKE them into strings. Peter will, of course, join in now to tell me that I'm wrong again. :)
The internal editor isn't a word processor - there's no need for it to be and it would take up *far* too much space if it was. You can, of course, write your programs in an external word processor if you wish. :)
Amnesie
Posted: 04:54pm 22 Feb 2023
Hello Mick,
this is an good idea, problem is that on German Keyboard layout the "inkey" is deaf to the following (physical) keys on the PS/2 Keyboard "äüöß" so I can't even read them in to process them after that.
Greetings
Daniel
Posted: 05:01pm 22 Feb 2023
I know that the PS/2 input can handle *some* high number codes, but I don't think it's all of them. Function and arrow keys all all high numbered codes, for example.
Posted: 05:02pm 22 Feb 2023
  Amnesie said  ... problem is that on German Keyboard layout the "inkey" is deaf to the following (physical) keys on the PS/2 Keyboard "äüöß" so I can't even read them in to process them after that.
So, just to be clear, if you have TeraTerm (not a VGA display) connected to the 'mite but type on the PS/2 keyboard then those keys produce nothing ?
Note that depending on the current PicoMite font, characters above ASCII 127 may not print anything to the VGA display, and what they print to a terminal depends on the code-page the terminal is configured to use.
Edited 2023-02-23 03:04 by thwill
Amnesie
Posted: 05:04pm 22 Feb 2023
Hm, okay.. so there is really no possibility, not even a workaround since the physical PS/2 keys are not recognized at all (on the specified keys "üöäß").
Posted: 05:07pm 22 Feb 2023
  Amnesie said  Hm, okay.. so there is really no possibility, not even a workaround since the physical PS/2 keys are not recognized at all (on the specified keys "üöäß").
If that really is the case then that would be a bug and I imagine Peter can probably fix it.
Does this produce nothing:
   a$=Inkey$
   If a$ <> "" Then Print "You pressed "; ASC(a$)
Amnesie
Posted: 05:08pm 22 Feb 2023
@ Tom
  Quote  So, just to be clear, if you have TeraTerm (not a VGA display) connected to the 'mite but type on the PS/2 keyboard then those keys produce nothing ?
I have connected both: A real physical PS/2 keyboard AND beeing connected via TeraTerm. And on the above program (with inkey) the mentioned keys via Serial work but won't on the real Keyboard connected via PS/2. They are ignored (while other keys work just normal as expected).
Amnesie
Posted: 05:10pm 22 Feb 2023
   a$=Inkey$
Tested it: correct, it produces nothing on the physical keys (üöäß) via PS/2. Other keys work just fine.
Posted: 06:07pm 22 Feb 2023
Maybe option keyboard maps the german keyboard keys that have alternatives on the us keyboard only. The special characters are igmored.
The pc keyboard driver will support all, since it is required in windows.
Note that full language support in windows is larger than the pico's flash. Somewhere you have to make a cut...
Edited 2023-02-23 04:12 by Volhout
twofingers
Posted: 06:11pm 22 Feb 2023
@Daniel
I found this:
https://www.thebackshed.com/forum/ViewTopic.php?TID=13297
It might explain something.
Michael
Posted: 06:21pm 22 Feb 2023
MMBasic is ASCII only. No umlaut, no acute accents, no pound sign. Anything you happen to get from teraterm is pure happenstance. The only thing you could do is use ON PS2 and interpret the scan codes.
Amnesie
Posted: 07:27pm 22 Feb 2023
Thank you Peter, at least this way I could read the scancode and interpret this with a custom font.
Greetings
Daniel
