Local Time 23:13 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SMD headphone socket equivalent
Posted: 03:21pm 19 Feb 2023
An equivalent to the usual SMD socket used on the CMM2 etc. appears to be available on ebay under the part number PJ-328. They are physically identical and look ok. I have some here and they drop into the PCB exactly as intended. The diagram in the adverts shows pins 4 and 5 (the switch contacts) reversed, but I think that's only numbers.
Usual 3.5mm Stereo Socket.
Switchcraft 35RASMT4BHNTRX (RS 705-1490, Mouser 502-35RASMT4BHNTRX).
EDIT:
Just tested it and it behaves as expected. At less than 1UKP each these seem to be a good alternative.
These are sold on ebay,sourced from China. They are also available from Amazon in the UK. Mine were on next day delivery. :)
Edited 2023-02-20 04:41 by Mixtel90
