Forum Index : Microcontroller and PC projects : Thanks TassyJim
| RicM Regular Member Joined: 05/02/2022 Location: AustraliaPosts: 61 |
Dear TassyJim, Thank you for the answer on the Size of the Font in the Editor. I have an another question what is the Bar character between SMALL |NORMAL Regards, RicM |
It means that there are options for the parameters. You chose only one. I am sure that at least one programming language uses | as the symbol for 'OR' Jim VK7JH MMedit |
