Local Time 00:13 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Building the PicoMite firmware on Raspberry Pi
Posted: 07:33pm 11 Feb 2023
Hi folks,
Has anyone attempted / succeeded in cross-compiling the PicoMite firmware from a Raspberry Pi ?
I've just tried it on a Pi 3 and the result is unusually large and non-functional.
Posted: 07:45pm 11 Feb 2023
Sounds like you are building a debug version. Also check what compiler version you have. Needs to be at least 10.x . I am using 11.2.1
Posted: 08:04pm 11 Feb 2023
  matherp said  Sounds like you are building a debug version.
No, I got that bit right, and I have previously built successfully on a gcc 11.3 Linux docker container hosted on Windows 10.
  matherp said  Also check what compiler version you have. Needs to be at least 10.x . I am using 11.2.1
That would be it, where does this specific GCC version requirement come from ? I can't see it published in neon lights anywhere ... I would have thought the SDK source-code would have included checks for the GCC version if it were critical.
Thanks,
led-bloon
Posted: 09:45pm 12 Feb 2023
I'm using gcc arm-none-eabi v10.3 which I got from the Arduino IDE packages some time ago,
and has probably been updated by now.
Built my own v12.2 from scratch but had problems linking to certain files, so ditched it.
led
Edited 2023-02-13 07:48 by led-bloon
Miss you George
Posted: 09:29am 13 Feb 2023
  led-bloon said  I'm using gcc arm-none-eabi v10.3
led
I also used 10.3 (via the RPi URLs back in July, I think they took me to the ARM download area for gcc etc).
John (must order a Pico W and find a way to connect it to something, somewhere...)
