Forum Index : Microcontroller and PC projects : ALL: LONGSTRING TRIM buffer%(),p% - Restricted to LLEN(buffer%())-1
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1159 |
░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ ░░ WORK IN PROGRESS CMM2 ░░ Please don't reply to thread ░░░░ ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ 5.07.02 Bugs (now all added to release notes. CMM2 Does it have MM.STARTUP PIcomite 6.00.01betas FUTURE ENHANCEMENTS. Single Dimension Arrays from 6.03.02 Bytecode and line length in header TileMap Does it apply to CMM2 MATH CLAMP MM.INFO (TELNET) Single Element Dimension Arrays Brief TODO /CHECK Check I2C with i char string here Some testing has shown the example in the manual won't work, I2C write is no longer happy with a 1 length string, not sure how long that has been the case. 6.03.00RC15 Adds standardised data flexibility for onewire, spi, i2c host and i2c slave read and write commands. Quote 'length' is the length of data to send or receive 'data' is the data to send or variable to receive. The data to send (WRITE) or the destination for received data (READ) may be supplied in any one of three forms: • A list of individual items. The number of items must equal the length parameter. For WRITE each item is a constant, variable or expression; for READ each item is a numeric variable to receive one value. Array elements such as a(3) are allowed. • An array, specified with empty brackets, e.g. array(). It may be a floating-point or integer array and must be large enough to supply (WRITE) or hold (READ) the specified number of elements, which are taken from / stored into consecutive elements starting at the first. • A string variable. For WRITE the first length characters are sent (the string must be at least that long); for READ the received bytes are stored as sequential characters and the string is set to that length. 6.03.00RC22 Bug fix to MATH(CROSSING function CMM2 MM.STARTUP MOUSE SET now sets the wheel position when enabled for a USB mouse (Picomite) SPRITE(B function now properly supports all orientations of the sprite)(Picomite) Sprinte(B SPRITE Manual STRUCTURES Structures Implemented in Beta12 DONE. RAYCASTER I2CLCD Command BITSTREAM Enhancement example ON ERROR RESTART Updated HUMID command extra parameter missing form H7 manual MODE 18 and OPTION DISPLAY in Option LIST Update manual with MODE RESOLUTION and font. Add new FKeys to manual in command line section STEPPER command? A number of command and function mappings used by the CMM2 were previously also applied to strings within MMBasic. This is now resolved. HUMID is not changed to BITBANG DHT22 inside a string. DHT22 is not changed to BITBANG DHT22 inside a string. HEX$( OCT$( BIN$( not changed to BASE$([2|8|16] inside a string. MM.INFO$ is not changed to MM.INFO inside a string. MM.INFO( is not changed to M.INFO$( inside a string. ERASE is not changed to CLEAR VARS inside a string. I2C I2C2 I2C3 SPI SPI2 are not changed inside a string. Peter, While copying some Picomite code to the CMM2 I think I see a potential problem with void MIPS16 SaveProgramToFlash(unsigned char *pm, int msg) ... about line 6009 // while (*p != 0xff) while(!(p[0] == 0xff && p[1] == 0xff)){ //guard against potential 0xFF in a token Check these from Picomites REDIM recreated arrays as the default type, losing INTEGER and STRING data. MATH CHI indexed past its table above about 8x8 and had wrong degrees of freedom under OPTION BASE 1; MATH M_INVERSE leaked a row per call; MATH CRC12 masking, the CRC reverseOut argument and Q_CREATE angle units were wrong; assorted argument checks in the MATH array helpers. JSON$ could read 8 bytes past its source array under OPTION BASE 1. CMM2 V6.00.00 Beta15 Update Regular expressions: {n} matched n or more times.Should be n times. Function DateTime$() now accepts integer. i.e. DateTime$(1) CMM2 V6.00.00 Beta14 Update Fixes Flash Not Erased error when binary copy of Font, CSub or CFunction pushes program to next 128K flash segement. Introduced at conversion to 16bit command tokens. Fixes Font7 % character being displayed mirrored. LOAD BMP now uses BmpDecoder.c from picomites in lieu of previous MS version. Dithering is not supported. The new decoder supports these BMP files: 1-bit (monochrome) - 2 colors with palette 4-bit - 16 colors with palette 8-bit - 256 colors with palette 16-bit - typically 5-5-5 RGB or 5-6-5 RGB 24-bit - 8-8-8 RGB (true color, most common) BI_RGB (0) - uncompressed (most common) BI_RLE8 (1) - 8-bit run-length encoding BI_RLE4 (2) - 4-bit run-length encoding MM.VER now returns a value to show release candidates as for latest Picomite. i.e. V6.00.00.xx where xx is 00-49 for Beta releases. xx is 50-99 for RC releases. MATH CRC12 function corrected to return 12bit result. (was incorrectly 16) MATH(CROSSING function Bug fix from Picomite. CMM2 V6.00.00 Beta13 Update HELP command alternative used at the command line if file a:/help.txt exists otherwise the CMM2 inbuilt help is used. The Editor still uses the inbuilt help. help.txt has same structure as Picomites. Fixed bug in MSGBOX function introduced on conversion to 16bit command tokens. Fix issue where an explicit END command was required at the end of a program when OPTION AUTORUN ON was used. Fixes two bugs in structures as per Picomite 6.02.01RC8 Fix bug in MEMORY INPUT when length is greater than 8, MEMORY INPUT fails with an End of File error. see here Fix to prevent HEX$( , BIN$( and OCT$( being replaced when part of a function name. Function POS returned. Was temporarily changed to MM.POS in Beta11. CMM2 V6.00.00 Beta12 Update CMM2 Beta12 Update Structures implemented. Separate manual in CMM2.zip BITSTREAM now a command (still available as BITBANG BITSTREAM) WS2812 now a command (still available as BITBANG WS2812) GPS checksum validation improved. New functionality for German keyboard characters that don't have an ascii representation by giving high value codes 200 upwards. VAR command restored, was missing with move to 16Bit commands. MOUSE(D,0) Fixed issue where the Double Click report was not cleared when read. Manual Updates. These existing functions added to manual. MOUSE(S,0) Reads current wheel value. MOUSE(Z,0) Reads wheel value and resets it to 0 References to MMEdit updated. References to FontTweak updated. Some missing MATH Commands/Functions added. Reference to Stuctures and MMBasic Structures.pdf added Commands and Functions that are structure aware have an indicator in the manual to signify this. e.g. ![]() CMM2.zip Updates. MMBasic Structures.pdf added to CMM2 download zip. Fontweak.zip added to CMM2 download zip. TODO: CMM2 V6.00.00 Beta11 Update CMM2 V6.00.00 Beta11 Update Command Tokens are now 16BIT so restriction on 128 commands is lifted. CMM2 V6.00.00 Beta10 Update Fixed error in LINSTR function V6.00.00Beta9 Onwards V6.00.00Beta9 CMM2 V6.00.00 Beta9 Update The firmware is also attached here in case you need to regress. Link to previous 6.00.00 Betas (Pre Beta9) CMM2 V6.00.00 Beta8 Update REGEX added/updated CMM2 V6.00.00 Beta7 Update Recompiled with STMCUBEIDE 2.0 and some STM32Drivers compiled for size to fix USBKEYBOARD issue. CMM2 V6.00.00 Beta6 Update CMM2 V6.00.00 Beta6 Update CMM2 V6.00.00 Beta5 Update CMM2V6.00.00.bin.zip TODO/CHECK ---------- OPEN COM1:9600,INV is sticky.Once INV is set it is not cleared when COM is closed. Fixed by clearing as part of setupuart() Fixes bug in day$(now) function Fix for ERASE var not recovering memory for array and string variables. (as per picomite) SETPIN pinno,CIN [,option] -Added as per PicoMite MM.INFO(OPTION VCC) added returns current value for VCC MM.INFO(BOOT) will return the reason for the last MMBasic Restart. “Power On”, ”Reset Switch”, “MMBasic Reset”, ”CPU RESTART”, “Watchdog”, “EXECUTE Timout” or “HEAP Restart”. These could be written to a log file in MM.STARTUP to see the history of an unattended device. OPTION NOCHECK [ON|OFF] added. I2C READ allows >255 chars if INT or Float array used.(as per Picomite) PIN("TEMP") adjusted to calculate using correct value of 130 degrees for REV V chips. BITBANG becomes DEVICE as per picomite latest release.(automatically converted) DEVICE BITSTREAM DEVICE LCD DEVICE HUMID DEVICE WS2812 Automatic length adjustment for string constants. Where a constant string is less that 16 characters no heap will be used. The data is stored within the pre-allocated table for the variable definitions. String variables defined with a LENGTH of less than 16 (was previously < 8) are also stored within the variable definition and require no heap allocation. TEMPR(Pinno [,timeout]) 'new optional parameter timeout to override the default (200mSec) to allow for slow devices. TEMPR START pinno [,resolution(0-3)] [,timeout] 'new optional parameter timeout to override the default (100, 200, 400, or 800mSec) to allow for slow devices. CMM2 V6.00.00 Pre Beta5 Recap TRIM$ CMM2 V6.00.00 Beta5 Update Edited 2026-10-20 12:45 by disco4now F4 H7FotSF4xGT |
