Forum Index : Microcontroller and PC projects : Original Colour Maximite can you add a USB mouse
| RicM Regular Member Joined: 05/02/2022 Location: AustraliaPosts: 61 |
Dear Members, Can you connect a USB mouse to the Orginal Colour Maximite using the 26 pin expansion connector. Regards RicM |
Not without an external processor which will more than double the cost of your mouse. Jim VK7JH MMedit |
You can using a serial mouse (if you can get one) see Or the Silicon Chip interface here Or the Hobbytronics USB host as used on the CMM2. And Jim has done it using an Arduino. Bill Keep safe. Live long and prosper. |
Not for USB, only PS/2 Jim VK7JH MMedit |
