Local Time 00:13 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Flash file system
palcal
Posted: 11:22pm 23 Jan 2023
I am re writing my weather station code to use the flash file system instead of saving to the DS3231 flash
I'm trying to open a directory and save some values, I have
  Quote  open "A:/weather" for output as #1
and I get   Error : Entry is a dir
I find it hard as I can't find any examples, what am I doing wrong?
Posted: 11:55pm 23 Jan 2023
Hi @palcal,
You don't "open a directory", you open a file in a directory.
Assuming the directory "A:/weather/" exists (if not then use MKDIR first) then:
open "A:/weather/my_file.txt" for output as #1
palcal
Posted: 12:05am 24 Jan 2023
Thanks I have never worked with directories so learning
palcal
Posted: 12:22am 24 Jan 2023
palcal
Posted: 01:17am 24 Jan 2023
OK got it working with..
open "A:/weather/data" for output as #1
print #1, rain
print #1, rainyest
print #1, rainyear
close #1
open "A:/weather/data" for input as#1
input #1, rain
input #1, rainyest
input #1, rainyear
close #1
print rain,rainyest,rainyear
Is there a way to Input and Output without using 3 lines, I tried...
print #1, rain, rainyest, rainyear
input #1, rain, rainyest, rainyear
but the second two entries returned zero
Posted: 01:25am 24 Jan 2023
rain =25
raintest = 100.5
rainyear = 1040.8
OPEN "A:/weather/data" FOR output AS #1
PRINT #1, rain;","; rainyest;","; rainyear
CLOSE #1
OPEN "A:/weather/data" FOR INPUT as#1
INPUT #1, rain, rainyest,rainyear
CLOSE #1
PRINT rain,rainyest,rainyear
You need to pout commas between the fields when printing to the file.
palcal
Posted: 01:38am 24 Jan 2023
OK Jim thanks for that.
palcal
Posted: 02:57am 24 Jan 2023
With my new Win 11 machine none of the function keys work with Teraterm, GFXterm or MMEdit.
the function key for screen brightness are OK.
Edited 2023-01-24 13:15 by palcal
Posted: 03:37am 24 Jan 2023
On some keyboards the function keys are dual purpose and you may have to switch them to "function keys"
This is very common on laptops and keyboards that are supplied by the big name manufacturers.
palcal
Posted: 04:58am 24 Jan 2023
Forget it.
Edited 2023-01-24 15:02 by palcal
Chrisk
Posted: 06:05am 09 Feb 2023
Hi Guys
I'm not sure why Palcal is using the DS3231 flash.
Isn't it an RTC. Does it have memory that can be written to?
Then once stored what do you Palcal  do with this data.
Just interested.
Chris K
Posted: 06:24am 09 Feb 2023
Most RTC modules also have a 24C32 memory chip which he was using, but now the Pico has a flash file system he is switching to that.
palcal
Posted: 07:36am 09 Feb 2023
@ Chrisk, yes I saved to the DS3231 flash. The code is somewhere here on the forum, I can post it if you want.
Chrisk
Posted: 05:08am 10 Feb 2023
Hi palcal
Tried to look it up with search but couldn't find it.
Please send when you have the time.
What is the advantage of using one over the other.
Quite often it is better to leave a functioning system alone unless there are real advantages.
Phill99.- Thanks Phill, I will look up the data sheet.
Chris K
Turbo46
Posted: 05:17am 10 Feb 2023
Maybe this is what you are looking for?
palcal
Posted: 05:23am 10 Feb 2023
Now I remember, it was Twofingers, I've been trying to remember so I could look it up.
I think probably easier to use than the Flash File system but that's just me and this will also work with the MMs
Turbo46
Posted: 05:35am 10 Feb 2023
My link above is to Michael's (Twofingers) post.
Chrisk
Posted: 08:47am 10 Feb 2023
Thanks Guys
The info in the link certainly had my head whirring.
Posted: 11:02am 10 Feb 2023
The flash file system is exactly the same as the SDcard file system that has been in Maximites and Micromites for ages.
The only difference is that, like LINUX, filenames are case sensitive so "file.bas" is different from "FILE.bas" etc. To make like easy keep everything in lower case and then you can forget about it.
It is very well described in the manual section on "Program and data storage"
Edited 2023-02-10 21:03 by matherp
