Local Time 02:09 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4W: bug with maximum label length
Posted: 11:50pm 21 Jan 2023
Hi Peter,
Apologies in advance.
I believe the maximum label length should be 32 characters, it is/was with MMBasic for DOS (and MMB4L), so is it possible something went "wrong" when you switched to hash lookup of labels? in which case presumably CMM2 and PicoMite are affected too?
On Error Skip 1
Goto goto_max_length_label_3456789012
my_return:
Print Choice(Mm.ErrMsg$ = "", "OK", Mm.ErrMsg$)
On Error Skip 1
Goto goto_too_long_label_1234567890123
Print Choice(InStr(Mm.ErrMsg$, "Label too long"), "OK", Mm.ErrMsg$)
On Error Skip 1
Gosub gosub_max_length_label_456789012
On Error Skip 1
Gosub gosub_too_long_label_234567890123
On Error Skip 1
Restore restore_max_length_label_6789012
On Error Skip 1
Restore restore_too_long_label_4567890123
Print Choice(InStr(Mm.ErrMsg$, "Variable name too long"), "OK", Mm.ErrMsg$)
End
goto_max_length_label_3456789012:
 goto my_return
gosub_max_length_label_456789012:
 Return
restore_max_length_label_6789012:
 Data 0, 1, 2
Expected:
> run
OK
OK
OK
OK
OK
OK
Actual:
> run
Error in line 2: Cannot find label
OK
Error in line 11: Cannot find label
OK
Error in line 19: Cannot find label
OK
twofingers
Posted: 12:32am 22 Jan 2023
  thwill said  ... in which case presumably CMM2 and PicoMite are affected too?
Can confirm for Picomite. Output from Picomite:
Saved 730 bytes
Cannot find label
OK
Cannot find label
OK
Cannot find label
OK
Posted: 01:53am 22 Jan 2023
My uneducated guess is, the hash table routines haven't allowed for the trailing zero byte.
In a lot of places in the source I see
MAXVARLEN + 1
but not in the hash table stuff.
Posted: 08:15am 22 Jan 2023
Don't care - won't be fixing
Posted: 08:41am 22 Jan 2023
Long labels are a pain to type anyway...
Posted: 09:45am 22 Jan 2023
long labels (and variable names) need to be "within reason" and on the slower platforms there can be really good reasons to avoid them
Edited 2023-01-22 19:46 by CaptainBoing
Posted: 11:31am 22 Jan 2023
  CaptainBoing said  +1 +1
Very valid arguments, but contrawise when writing a sufficiently complex piece of software with many modules long identifiers are exceeding useful to make the code readable and avoid naming conflicts.
Anyway, not really what this was about, the "spec" says identifiers are 32 characters, I found a case where this was not true, Peter isn't going to fix it, neither am I at the moment (except for MMB4L), job "done".
Posted: 12:00pm 22 Jan 2023
OK, here is another unexpected 31 character limit, slightly more significant since it happens with functions rather than (obsolete) labels.
> list
Option Explicit On
On Error Skip
Dim i% = fun_with_max_length_name_6789012%()
? Choice(Mm.ErrMsg$ = "", "OK", "Caught: " + Mm.ErrMsg$)
Function fun_with_max_length_name_6789012%()
 fun_with_max_length_name_6789012% = 42
End Function
> run
Caught: Error in line 7: Variable name too long
I believe the problem is in MMBasic.c#skipvar():
const char *skipvar(const char *p, int noerror) {
   const char *pp;
   const char *tp;
   int i;
   int inquote = false;
   tp = p;
   // check the first char for a legal variable name
   skipspace(p);
   if(!isnamestart(*p)) return tp;
   do {
       p++;
   } while(isnamechar(*p));
   // check the terminating char.
   if(*p == '$' || *p == '%' || *p == '!') p++;
   if(p - tp > MAXVARLEN) {
       if(noerror) return p;
       error("Variable name too long");
Note how the 1 character type extension is incorrectly (at least it doesn't seem to be counted in findvar() or stored in the name field of vartbl) being included in the variable name length check.
Edited 2023-01-22 22:00 by thwill
Posted: 12:03pm 22 Jan 2023
Nobody uses names this long. I'll get the manual changed to say the maximum for labels and functions is 31
Posted: 12:22pm 22 Jan 2023
  matherp said  Nobody uses names this long. I'll get the manual changed to say the maximum for labels and functions is 31
It depends on whether you use the extension, and it's actually 30 for function names in some cases because later on skipvar() counts the opening bracket when its determining the name length:
   pp = p; skipspace(pp); if(*pp == '(') p = pp;
   if(*p == '(') {
       // this is an array <--- also not necessarily true.
       p++;
Also it appears in the presence of a type extension, variable names may be limited to 31 chars too when the interpreter goes through skipvar().
All, I'd appreciate some advice here, I get the feeling I may not be making friends and influencing people. Do I keep these things to myself or do I keep bringing them up?
Edited 2023-01-22 22:24 by thwill
Posted: 12:32pm 22 Jan 2023
By all means bring them up IFF like the GOSUB you provide solutions. But these extreme edge cases that no-one is going to find in the real world or if they do can work round without issue seem to me pointless for a hobby focused product.
Changing, for example, skipvar could have many unforeseen consequences that the fixing the "bug" can't justify
Edited 2023-01-22 22:34 by matherp
Posted: 12:36pm 22 Jan 2023
  matherp said  By all means bring them up IFF like the GOSUB you provide solutions. But these extreme edge cases that no-one is going to find in the real world or if they do can work round without issue seem to me pointless for a hobby focused product.
Thanks.
  Quote  Changing, for example, skipvar could have many unforeseen consequences that the fixing the "bug" can't justify
This is because you don't have unit-testing, which is designed to catch those unforeseen consequences . As it happens skipvar() is only used in a handful of places, I'll work on a fixed version for you and then you can make your own choice.
Edited 2023-01-22 22:37 by thwill
Posted: 12:46pm 22 Jan 2023
  thwill said
...it appears in the presence of a type extension, variable names may be limited to 31 chars too ...
It does. I am presuming this section of source is ancient and so largely aplicable to most (all?) versions.
I noted this point here: "you can see this 32 character thing for yourself if you try to define a variable with 32 character name, then do the same with a type indicator. It breaks. Remove one character (so now it's 31 chars long) and you can specify the type."
Posted: 12:59pm 22 Jan 2023
  CaptainBoing said  It does. I am presuming this section of source is ancient and so largely aplicable to most (all?) versions.
I suspect so.
  CaptainBoing said  I noted this point here:
Indeed you did. It looks like findvar(), at least in Peter's versions and IIRC "MMBasic for DOS" doesn't consider the extension when evaluating the variable name limit, but skipvar(), which is also used to skip function prototypes/calls does.
If I can fix it for MMB4L then I'll port the changes to MMB4W and Peter and Geoff can take it from there if they wish.
Edited 2023-01-22 23:01 by thwill
Posted: 12:53pm 23 Jan 2023
I'm happy you're finding them.
I'd be happy if the manual changed to say max 30 (to cover all the above).
I'm fairly sure I've never "needed" even 30 :)
Posted: 12:56pm 23 Jan 2023
  thwill said  This is because you don't have unit-testing
It's great you're making the tests.
As you know, they're hard work, though, and time-consuming.
Please don't be put off.  I feel overall that MMBasic will get even better.
Posted: 01:21pm 23 Jan 2023
  JohnS said  It's great you're making the tests.
Thanks John.
  JohnS said  I'd be happy if the manual changed to say max 30 (to cover all the above).
My recommendation is to leave the manual as it is for the moment since only I (and The Captain on the older 'mites) seem to have noticed these edge-cases; 32 is a much nicer number than 30.
When I've finished my current iteration of MMB4L I'll cross-port some fixes to MMB4W (not completely trivial because MMB4L has considerably rewritten identifier handling which I don't intend to port) which Peter may or may not consider for his other ports.
Posted: 02:11pm 23 Jan 2023
  Quote  32 is a much nicer number than 30
42 is even nicer. Is anyone porting Deep Thought to the PicoMite?
(Grabs towel and copy of HHGTTG. Runs away...)
