Local Time 02:08 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New 10c RISC-V chip...
Posted: 08:25am 20 Jan 2023
EEVblog video...
Perhaps Peter the miracle-worker, can port MMBASIC to this thing.
I'm joking, naturally.
Posted: 09:12am 20 Jan 2023
That's really impressive - and a good replacement for some of the PIC range. Microchip might have some of their work cut out if these things catch on.
(Peter hasn't quite completed his port to the Cray 1 yet, so he's a bit busy. ;) )
Posted: 11:12am 20 Jan 2023
going RISC5 is a good thing, assembler becomes portable outside of a single supplier
Posted: 12:07pm 20 Jan 2023
Have they made the I/O portable?
i.e. unlike ARM - where every major chip maker designs their own I/O thus making MMBasic need a pile of new I/O code for each change of chip.
Posted: 12:44pm 20 Jan 2023
RISC-V specifies the instruction set and some extensions (you can also have non-standard extensions). I suspect that any IO handling will be down to compiler libraries for the hardware you are working on.
Posted: 01:33pm 20 Jan 2023
  Mixtel90 said  RISC-V specifies the instruction set and some extensions (you can also have non-standard extensions). I suspect that any IO handling will be down to compiler libraries for the hardware you are working on.
Thanks.
Essentially the same situation as ARM, then, so will need lots of effort to port MMBasic (*), it seems.
If the CPUs are cheap enough & powerful enough, with guaranteed availability, may happen I guess.
Meanwhile the RPi Pico is excellent features & performance for the money!
(*) MMB4L probably vastly less work :)
Posted: 03:51pm 20 Jan 2023
sadly unlikely any port with the flash and ram sizes, certainly this particular chip
Posted: 01:39am 21 Jan 2023
I do need to stress that I was in no way suggesting that MMBASIC could or ever would be ported to this device - note my winking face emoji in the first post.
10c and you get a UART, SPI, and I2C port, 18 GPIO, 10-bit ADC, 16KB FLASH, 2KB SRAM and and 48MHz speed.
Very impressive for a whole ten cents!
But with 16K of flash and only 2K of RAM, porting MMBASIC to this thing would be impossible I would think.  Peter might chime in here, but I think it is safe to say that will never happen.
But you MIGHT see things like Great Cow BASIC moving to the RISC-V stuff - perhaps, but even if they did, it would not be anytime soon.
What I'm saying is, don't get your hopes up that these can ever run MMBASIC.
Posted: 07:50am 21 Jan 2023
Irrespective of the word length they are more targeted at the PIC16-high / PIC32-low section of the market, which is still a very profitable one for Microchip. Nope, not MMBasic territory but a definite opportunity for a BASIC compiler or even some sort of "Tiny BASIC" interpreter. Mind you, if they aren't available we'll never know. :)
Posted: 12:37pm 21 Jan 2023
oh yes!  (Are you watching Evan?)
