Local Time 02:10 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : datatype of CTRLVAL() if numeric ?
ville56
Posted: 08:05pm 19 Jan 2023
2nd try, now in the proper forum ....    mea culpa, mea maxima culpa!
I'm trying to read a float value from a NUMBERBOX via the CTRLVAL() statement. If i enter 89.9 in the numberbox, a PRINT CTRLVAL() returns 89.90000153.
This seems to be in contrast to an assignment like i=val("89.9"), i being declared as float datatype, which gives 89.9 on "print i".
Is there a lower (single?) precision for the internal representation/conversion of CTRLVAL than for normal float variables or do i something wrong ?
Any clarification is welcome
Regards, Gerald
73 de OE1HGA, Gerald
Posted: 08:44pm 19 Jan 2023
That's floating point (IEEE 754) for you.
PRINT STR$(....) will display it in whatever resolution you desire.
You have to take precautions if you are checking for equality.
ville56
Posted: 09:22am 20 Jan 2023
Thanks for the info about float format, Jim. But there ist still something strange for me.
I've tried the following:
dim float i
i=89.9
print i
  Result is: 89.9 and what i expected it to be.
--- but ---
'gui components are defined somewhere upfront
ctrlval(#1)=89.9
print ctrlval(#1)
  Result is: 89.90000153 this seems like 32 bit representation ... unusable for my problem. Same behavior if you enter the number via the touchpad.
So there is appearantly some inherent difference in assigning a numeric value to a 'normal' float variable and the assignment of the value to the ctrlval() command. Variables seem to be 64 bit, ctrlval() assignments seem to be 32 bit, be it direct assignment as in my example or assignment via the touch entry.
What i want to know is, is there a way to have 64 bit resolution for touch input of float numbers, or why there is currently no 64 bit resolution for that.
Thanks, Gerald
Posted: 10:01am 20 Jan 2023
Nasty, unpredictable things, floats. Do everything in integers and just multiply/divide them by powers of 10. ;) Better still, do everything in binary or, if you must, HEX. :)
>**** ERROR *** REBOOT UNIVERSE TO CONTINUE ***
More seriously, I rather suspect that the GUI commands might be taken pretty much as they are from the 32-bit MMBasic systems. They may not handle 64-bit values properly and could be ignoring the upper bits. I've not used them much so I can't offer any practical experience.
Posted: 10:07am 20 Jan 2023
  Mixtel90 said  >**** ERROR *** REBOOT UNIVERSE TO CONTINUE ***
More like "Click [OK] to reboot universe" and then not show any buttons ... or worse yet not show a [Cancel] button.
ville56
Posted: 10:53am 20 Jan 2023
hmmm ... seems to be a break in the floating point arithmetics architecture of MMBasic on the pico.
I'm not a big fan of floating arithmetics anyway, do whatever i can in integer. Had a lot of "bad" experiance with rounding errors in my 'industrial' live, long time ago, programming realtime process control. Later in my 'banking' live, integers where almost the only way to do it.
So i have to revert to integers, or maybe strings...
Reset Universe?
     O Yes
     O No
     X Not sure
Thanks to all, Gerald
Posted: 11:56am 20 Jan 2023
The PicoMite uses floats for GUI operations to save memory - 16 bytes per control. I'll change the formatting to fix the issue in the next 5.07.07 beta
ville56
Posted: 02:38pm 20 Jan 2023
Peter, thank you. This will make things easier for me.
Regards, Gerald
Posted: 03:05pm 20 Jan 2023
Please check V5.07.07b7 just posted to see if it works - thanks
ville56
Posted: 04:23pm 20 Jan 2023
Just tried V5.07.07b7, no change in behavior.
Regards, Gerald
Posted: 04:52pm 20 Jan 2023
Can you post your program or a simple demo program so I can test
Edited 2023-01-21 02:54 by matherp
ville56
Posted: 07:48pm 20 Jan 2023
created 2 progs
- gui-1.bas shows the difference between storing a value in a float variable vs ctrlval() which should behave the same. A typical value where the difference shows up is 89.9
- gui-2.bas lets you enter a value into a numberbox and prints it. If you enter 89.9 you get the same difference as shown in gui-1.bas
Both examples point, in my opinion, to differences in the internal representation of floating point numbers (variable vs. gui subsystem)
guitest.zip
Hope this shows what my problem is.
Reagrds, Gerald
