Forum Index : Microcontroller and PC projects : PicoMite and "LCD Display as the Console Output"
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Hi! Little question: I have an "Pico-ResTouch-LCD-3.5" and would like to use it as Console Output. The manual says: When I enter the command "OPTION LCDPANEL CONSOLE" I get this error message: The display has a ILI9488W controller. Is the controller really that different from the ILI9488 or am I doing something wrong??? Thanks! Frank |
It really is, due to the way it's (not) connected. (MISO or some such is absent - previous thread somewhere.) John |
https://www.waveshare.com/wiki/Pico-ResTouch-LCD-3.5 It says that MISO would be connected to GP12... Frank |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9259 |
It hasn't got a proper SPI interface. It simulates one using shift registers so MISO for the display can't work as it hasn't got one. MISO for touch and the SD card is present though. Edited 2023-01-13 02:55 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
MISO may be connected to GP12, but alas, that is unrelated to the LCD. The LCD is used in 16 bit parallel mode, with 'HC4094 shift registers to turn MOSI into parallel. The RDX line is pulled high so some serious hacking would be required to get Read mode to work. Visit Vegipete's *Mite Library for cool programs. |
Thanks for the answers! BAD! - the display would have been quite nice (it has a good resolution and a very nice picture quality) and you just had to put it on... Frank |
