Local Time 04:05 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with "PLAY WAV" and PicoMite 5.070606
Frank N. Furter
Posted: 08:57pm 30 Dec 2022
Hi!
I want to play a few WAV files in continuous loop for a future Halloween project. Unfortunately I get an error message after some playback time. The WAV are on the flash drive (PicoMite 5.070606).
Option Explicit
Dim WAVbusy As INTEGER
Const TRUE=1
Const FALSE=0
 WAVbusy=TRUE
 Play wav "WIZSIT.wav",IROUTINE
 Loop While WAVbusy=TRUE
 Pause 5
 WAVbusy=TRUE
 Play wav "MUMSIT.wav",IROUTINE
 Pause 5
 WAVbusy=TRUE
 Loop While Wavbusy=TRUE
 Pause 5
 WAVbusy=TRUE
 Play wav "MINACT.wav",IROUTINE
 Pause 5
Sub IROUTINE
 WAVbusy=FALSE
IReturn
It works for some time, then I get this error message:
  Quote  [27] Loop While Wavbusy=TRUE
Error : Too many SUBs for interrupt
Here are my WAV files: WAV.zip
What am I doing wrong??? Is there any way to make it easier to query for the WAV end???
THANKS!
Frank
twofingers
Posted: 09:01pm 30 Dec 2022
@Frank
From manual
  Quote  IRETURN
Returns from an interrupt when the interrupt destination was a line number
or a label.
New programs should use a user defined subroutine as an interrupt
destination. In that case END SUB or EXIT SUB will cause a return from
the interrupt.
Michael
Frank N. Furter
Posted: 09:26pm 30 Dec 2022
Do you think I should exchange IReturn for END SUB? I do not fully understand the text from the manual...
Frank
Posted: 09:36pm 30 Dec 2022
Yes. An interrupt routine is now a normal SUB so IRETURN isn't required. END SUB or EXIT SUB can be used as usual.
Frank N. Furter
Posted: 09:45pm 30 Dec 2022
Thank you both so much!!!
Now it works as it should.    The program now looks like this:
Option Explicit
Const TRUE=1
Const FALSE=0
 PlayWAV "WIZSIT.wav"
 PlayWAV "MUMSIT.wav"
 PLAYWAV "MINACT.wav"
Sub PlayWAV wav$
 WAVbusy=TRUE
 Play WAV wav$,IROUTINE
Sub IROUTINE
 WAVbusy=FALSE
MANY THANKS!!!
Frank
twofingers
Posted: 09:53pm 30 Dec 2022
  Frank N. Furter said  Now it works as it should.
Cool!
and "guten Rutsch!" (happy New Year!)
Frank N. Furter
Posted: 03:26pm 31 Dec 2022
    Dito!
Frank
