Forum Index : Microcontroller and PC projects : PicoMite: Counting Input Questions
| DrifterNL Regular Member Joined: 27/09/2018 Location: NetherlandsPosts: 58 |
Hi again, What is the maximum frequency and minimum pulse length that can be used on a pin configured for counting to still get a reliable count? Floating Point Keeps Sinking Me! Back To Integer So I Don't Get Injured. |
| IanRogers Senior Member Joined: 09/12/2022 Location: United KingdomPosts: 152 |
Did you read this thread.. www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15380 Sorry can seem to make a link Edited 2022-12-21 18:51 by IanRogers I'd give my left arm to be ambidextrous |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6204 |
Short answer: The picomite SETPIN gpx,FIN function Up to 50kHz it is accurate error < 1% Up to 200kHz you are looking at 2-3 % error Up to 500kHz you have up to 20% error It also depends on the CPU load. in example, if you have OPTION AUDIO set,the CPU can be more busy and faults get larger. Volhout Edited 2022-12-21 23:46 by Volhout PicomiteVGA PETSCII ROBOTS |
Try V5.07.06b6 - accuracy much improved. Tested at 500KHz with CPU speed 378MHz. |
Hi all, I'm actually asking about the SETPIN pin,CIN function, and how high the frequency and short the pulse can be before the picomite starts to miscount. I'm using V5.07.05b15 Edited 2022-12-22 01:06 by DrifterNL Floating Point Keeps Sinking Me! Back To Integer So I Don't Get Injured. |
Use 5.07.06b6 it improves FIN, CIN, and PER At base CPU frequency I've just tested with 200KHz and pulse width of about 40nS CIN behaves the same as FIN Edited 2022-12-22 01:16 by matherp |
Thanks for all the responses. Looking at the posted frequencies and pulse width the PicoMite should easily count pulses that have a width of ~5ms and frequency of ~28Hz. I'll be sure to update to the latest firmware. Floating Point Keeps Sinking Me! Back To Integer So I Don't Get Injured. |
