Forum Index : Microcontroller and PC projects : Command Window query
| Bowden_P Senior Member Joined: 20/03/2019 Location: United KingdomPosts: 176 |
Hi everyone, I have a PC running Windows 10 with a SSD drive C:, and a conventional disc drive D:. I am trying to use Serge's "pic32prog" for the first time on this machine, wishing to run it from drive D:, but can't get the Command Window prompt to point to this disc. It sticks to the C: drive. The "Help" list of commands doesn't seem to have one that specifically changes the disc, and attempts with "CD" or "CHDIR" and "D:\pathname" don't work. I don't get any error message, just no action on the command, and no change of disc. Is it possible to change discs within the Command Window - or by some other means - to run from the D: drive? With best regards, Paul. Nothing so constant as change. |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1159 |
Google says this. Seems to work. This opens a command prompt in D:\movies when entered from Run menu in windows. cmd.exe /K "cd /d D:\movies\" F4 H7FotSF4xGT |
Hi disco4now, I wasn't sure where the "Run menu" you refer to was - I'm showing my ignorance of PC's here - but typing :- cmd.exe /K "cd /d D:\Paul\Paul's Stuff\Micromite\Firmware and other Code\Microbridge to PIC32 hex transfers" into the "Type here to search" box bottom left of the desktop screen opens a Command window where I need it! ( I hope that is where you refer to.) Many thanks for this, Paul. Nothing so constant as change. |
Run is a menu item if you right click on the window icon at bottom left,but looks like the search thing does the job as well and one less step. F4 H7FotSF4xGT |
Hi disco4now, Thanks for that - a much better way to get to the Command prompt where I need it. That right click is a whole new menu for me! With best regards, Paul. Edited 2022-12-04 09:23 by Bowden_P Nothing so constant as change. |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418 |
DOS has always been a bit funny. Typing CD D:\TEMP changes the directory in drive D: but not to drive D: To do that just type D: <enter> |
Hi phil99, Well I never - thanks. Yes, DOS is certainly odd. I guess it harks back to the dawn of PC's, when Windows and mice didn't exist. I've managed to find the cmd.exe in "C:\Windows\System32", created a shortcut, and then edited the target to start it with disco4now's /K "cd/d D:\pathname......" extension - gets me there directly. ( space required before the /K ) Brilliant ! With thanks to you both, Paul. Nothing so constant as change. |
