Local Time 06:05 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic parameter List Bug?
vegipete
Posted: 02:09am 29 Nov 2022
Am I doing something wrong or have I mis-read the manual or ...?
It seems that if the first (non-whitespace) character after a subroutine call is an open bracket, then the entire list of parameters must be enclosed in extra brackets.
Edit: I am testing this on a CMM2. Do other platforms behave similarly?
> ? mm.device$
Colour Maximite 2
> ? mm.info(version)
 5.0702
> list
' test subroutine call
testme 1,2,3,4
testme 2/2,2,3,4
testme (1+1)/2,2,3,4  ' broken?
testme ((1+1)/2,2,3,4)
testme 2/2,(1+3)/2,3,4
end
sub testme a,b,c,d
  print a,b,c,d
end sub
> run
 1       2       3       4
 1       2       3       4
 2       0       0       0
 1       2       3       4
 1       2       3       4
Edited 2022-11-29 12:10 by vegipete
Posted: 04:56am 29 Nov 2022
You are correct.  If the parameter list starts with a bracket, then the parameter list must also be terminated with a bracket (ie, all the parameters must be enclosed within the brackets).
When subroutines were added to MMBasic (a long, long time ago) it was made mandatory that the parameter list be enclosed within brackets as specified in the ANSI Standard.  But later the brackets were made optional.  These days the user manuals and most programs do not use brackets.
So you can use two forms:
       mysub(arg1, arg2, etc)
or
       mysub arg1, arg2, etc
You have stumbled across this "feature" of the interpreter where it spotted the starting bracket and assumed that the whole parameter list was bracketed.  This applies to all versions of MMBasic.
