Local Time 06:05 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: minor Nunchuk/Classic controller "bug"
Posted: 11:29am 21 Nov 2022
Hi Peter,
It appears to be currently possible from MMBasic to open a Wii controller and then read from it before the firmware has performed the first (16 mSec) poll of the controller resulting in the "initial values" being returned (these appear to be zeroes, but I think I saw "garbage" on one occasion that I can't now reproduce.)
It's easy enough to workaround (add a short PAUSE), but you might want to consider updating the firmware to force a poll immediately after the controller has opened, or equivalently add a pause at the end of the OPEN routine; assuming that won't block the poll.
Edited 2022-11-21 21:29 by thwill
Posted: 01:15pm 21 Nov 2022
Try this (untested)
CMM2.zip
Posted: 01:27pm 21 Nov 2022
Thanks Peter,
  matherp said  Try this (untested)
Bill (@Turbo46) would you test this on your Nunchuck, don't forget to remove the PAUSE that you added. I'll test it with the Classic.
Turbo46
Posted: 01:05am 22 Nov 2022
Sorry, that didn't work for me. I still get zeros for the first readings of JX and JY.
Turbo46
Posted: 06:16am 22 Nov 2022
I had some problems with this firmware. A couple of times the keyboard would not work. Because I had the wrong keyboard option set (UK not US), I changed the keyboard option.
After that the keyboard only worked very occasionally after powering down and up. No console to teraterm either. I tried another keyboard and power supply and got no improvement.
Eventually I re-flashed the CMM2 with 5.07.02b6 and all is good again.
It was a bit flaky before I changed the keyboard.
Posted: 10:13am 22 Nov 2022
Try again. I've reverted to an older version of the IDE. It is the only change that could affect USB since RC6
CMM2.zip
Turbo46
Posted: 11:06am 22 Nov 2022
Thanks Peter I'll try it out tomorrow for the USB problem but it didn't help with the initial problem before I tried to change the keyboard.
Posted: 11:07am 22 Nov 2022
I have made a further change to the controller check in the latest. Somehow I think you found a 2mSec window
Turbo46
Posted: 11:27am 22 Nov 2022
Thanks again Peter, Murphy's law always works against me. I will try again tomorrow.
Turbo46
Posted: 09:10pm 22 Nov 2022
Sorry again, while I can change the keyboard back and forth with no problems now, JX and JY still read zero for the first time. There is a 250mS delay in my test program before I read it again to give me time to see that first reading.
Posted: 10:44pm 22 Nov 2022
The controller has been polled multiple times in 250mSec so there is nothing more I can do. My "fix" was just to make sure one poll happens before the OPEN command completes.
Turbo46
Posted: 11:04pm 22 Nov 2022
Thanks for trying Peter, I guess a pause 16mS or more before polling the Nunchuk will work. Or a do - loop waiting for a non zero value. (and they do)
Posted: 09:30am 23 Nov 2022
One more try
I found a variable that wasn't labelled volatile that is changed in the interrupt routine so it is possible the issue was a caching/optimisation issue
CMM2.zip
Turbo46
Posted: 10:12am 23 Nov 2022
SUCCESS! Thanks Peter, there are no zero readings on jx and jy on my first reading of the Nunchuk. No PAUSE or DO...LOOP needed.
I hope that fixes any issues for Tom with his Classic.
Thanks again.
Posted: 10:20am 23 Nov 2022
Lovely, I'll give it a thrash with the Wii Classic Controller at the weekend.
Thanks for your dogged determination Peter.
toml_12953
Posted: 09:50am 26 Nov 2022
  matherp said  One more try
CMM2.zip
Does this have all the features of the beta CMM2V5.07.02b6? If not what's the latest version?
Posted: 04:38pm 28 Nov 2022
  thwill said  Lovely, I'll give it a thrash with the Wii Classic Controller at the weekend.
I've briefly tested it (better late than never) and as far as I can tell it is now behaving itself. Thanks again Peter.
  toml_12953 said  Does this have all the features of the beta CMM2V5.07.02b6? If not what's the latest version?
I assume so. It reports itself to be 5.07.02b8 but I don't know if Peter has "officially blessed" this as beta 8 or that is an "accident".
Edited 2022-11-29 03:06 by thwill
