Local Time 06:52 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 G2 availability update
Posted: 01:26pm 17 Nov 2022
Out of interest I just loaded the CMM2 G2 gerbers to JLC. They are currently showing all the parts in stock to build 5 boards. Prices are much higher but not completely crazy.
Total price for 5 populated boards is showing as GBP321.34 i.e. GBP65 each.
On top of this you would need connectors, SDcard socket, mains switch, battery socket and battery and optional case.
Unfortunately JLC seem to have changed their software such that the component placement spreadsheet doesn't seem to position things correctly any more. However this should be easy enough to fix.
So: Looks like building a CMM2 is now a possibility again
Posted: 02:42pm 17 Nov 2022
Attached is an updated component placement file that fixes the JLC issue. Otherwise just use the gerbers and BOM from Geoff's site
JLCCPLV2.1.zip
Posted: 08:16pm 17 Nov 2022
Peter,
Out of interest, (I am not going to produce any more CMM2)  how do you define that you are getting a 480MHz part that the G2 really needs, given that STM don’t seem to differentiate between the 400 MHz and 480 MHz parts?
It’s good news that stock looks like it may start to be moving again.
Posted: 10:36pm 17 Nov 2022
No way of defining 480 vs 400 as they are the same part no. Has always been like that.
You can assume that new stock will all be 480 but if JLC have found a stash of old parts then you can't be certain.
geeken
Posted: 07:45am 20 Nov 2022
Any interest in the shared purchase of a batch of these new G2's ?
Posted: 12:06am 21 Nov 2022
Good luck with the batch idea, geeken!
LCSC says ONE in stock and can ship in three days.
