Local Time 06:53 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Manual Error - Nunchuk function
Turbo46
Posted: 12:13am 14 Nov 2022
Sometime after CMM2 MMBasic V5.06.00 the Nunchuk function description in the manual changed from:
NUNCHUK(funct [, channel])
to:
NUNCHUK(channel, funct)
This appears to be wrong. As the manual says, the channel is optional and if omitted it will default to channel 3 which is the one used for the front connector on the original CMM2.
The CMM2 does not accept the second version of the command.
Turbo46
Posted: 10:58pm 16 Nov 2022
Found more problems in the CMM2 manual.
The CALL function is missing from the bookmarks although the description is there.
Between the MEMORY and MID$ command bookmarks there are a couple of misplaced bookmarks which take you to the middle of a description.
Posted: 10:25am 18 Nov 2022
Additional CMM2 manual issues:
- the description of the CLASSIC() function says "T returns the ID code of the controller - should be hex &H4200101" ... that's incorrect it is hex &HA4200101.
- MEMORY COPY and MEMORY SET are undocumented.
Edited 2022-11-18 20:25 by thwill
