Local Time 06:54 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite 2's MMEdit - How to put .BAK files in a separate folder
dvanaria
Posted: 01:27am 12 Nov 2022
Is there a system command/setting that will redirect all backup files that MMEdit creates into another folder? Or optionally, prevent .BAK files from being created?
I'm finding that the .BAK files create a lot of clutter in my working directory.
Posted: 07:45am 12 Nov 2022
Not as far as I know, but you can use the RENAME command to move your BAK files to a different directory if you wish.
I can't currently test this, but it might work. I can't remember how the CMM2 handles wildcards.
RENAME *.BAK AS backfiles/*.BAK
If you like to live without a file safety net you can probably get rid of them with:
KILL *.BAK
But I wouldn't recommend it.
I don't think there's a way of preventing them from being created - after all, it's a file safety device. :)
Posted: 09:03am 12 Nov 2022
What version of MMEdit?
Are you referring to *.bak files or files with a timestamp added to the *.bas file name?
Turbo46
Posted: 11:37am 12 Nov 2022
Are you thinking of the .bak files that the CMM2's editor creates? they tend to add uo.
Posted: 11:36pm 13 Nov 2022
I think you are right, he is talking about the CMM2 editor, nothing to do with MMEdit
In that case,
'backup move
OPTION EXPLICIT
OPTION DEFAULT INTEGER
DIM f$
f$ = DIR$("*.bak", FILE)
 DO WHILE f$ <> ""
   COPY f$ TO "/backup/"+f$
   'kill f$
   PRINT f$
   f$ = DIR$()
 LOOP
You need to create a "backup" folder.
There isn't a MOVE command so we have to COPY and DELETE
I suggest you leave the KILL line remmed out until you are happy that the selected files are what you expect.
Edited 2022-11-14 09:36 by TassyJim
dvanaria
Posted: 06:34pm 15 Nov 2022
Thank you, that works well. I'll leave the KILL line remarked out. The backups have already saved me more than one time, so they are definitely good to have.
Sorry for the confusion with the name of the editor, I thouht MMEdit was the name of the CMM2's editor. I didn't realize they are completely different programs. You're correct that I was just referring to the CMM2's editor. I'll try to correct the title of this forum post to reflect that.
Posted: 06:57pm 15 Nov 2022
  Mixtel90 said  Not as far as I know, but you can use the RENAME command to move your BAK files to a different directory if you wish.
Hi Mick,
Doesn't work, and nor does KILL *.BAK. AFAIK only LS/FILES performs any sort of globbing on the CMM2.
  TassyJim said  ... There isn't a MOVE command ...
Hi Jim,
I don't have access to my CMM2 at the moment to confirm, but I believe you are mistaken and that RENAME will perform a MOVE.
Edited 2022-11-16 05:02 by thwill
Posted: 07:22pm 15 Nov 2022
I am sure you are right. It should work but all I get is:
Error in line 8: Access denied due to prohibited access
I haven't investigated further.
Posted: 08:30pm 15 Nov 2022
Found the problem with RENAME (in CMM2 V 5.0701)
It doesn't like the double dots in the destination name.
This works:
'backup move
OPTION EXPLICIT
DIM f$, d$
 DO WHILE f$ <> ""
 d$ = "A:/backup/"+LEFT$(f$,LEN(f$)-7)+"bak"
 PRINT f$+" >>> "+d$
   RENAME f$ AS d$
   f$ = DIR$()
 LOOP
I don't think it needs the absolute path but not happy with ".BAS.BAK" even though it is OK when using COPY.
