Local Time 06:54 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Brain fade - help wanted for simple algorithm - logic puzzle
Posted: 03:23pm 11 Nov 2022
Flash memory can only be written by converting bits set to 1 to 0.
When flash is erased all bits are set to 1
Therefore if a byte is set to &HFF then by definition it can be overwritten
but what if the byte in flash is &Bxyxyxyxy where x and y are either 1 or 0
Can it be overwritten by a replacement byte &Babababab ?
At a bit level this is easy:
OK_to_overwrite=1
For all bits in a byte
if bit in flash = 0 and bit in replacement = 1 then
  OK_to_overwrite=0
  exit for
endif
next
But it should be possible to do this at a byte level using a single statement combining XOR/AND/OR/NOT is some way.
I can't see it at the moment so ideas appreciated for the most efficient algorithm
Posted: 03:55pm 11 Nov 2022
from my experimenting a while back, I found the writing of bits to be ANDed between what's already there and what you want to write. You can write to a given cell any number of times, but it is always an aggregation of the zero bits.
I do touch on this in my article here (hate to bang the drum but at least it is pertinent this time)... back in the 80s I had use of an EPROM programmer that would read the ROM, AND it with your target code and then decide if you could burn it in without erasing - same process, only zero bits got burned and if you tried to burn a 1 over an existing 0 it would result in a corrupt ROM. Saved time occasionally. It used to take 30mins to erase the darn thing but I don't remember being able that often to burn a new image over an old. Was always a dozen "spare" EPROMS in the eraser.
Edited 2022-11-12 02:06 by CaptainBoing
Posted: 04:00pm 11 Nov 2022
If (current & new) == new then it can be programmed
Posted: 04:04pm 11 Nov 2022
Don't understand. 0 can be written on top of 0 so AND doesn't work unless I am missing something
A XOR B gives the bits that are different but 1:0 is OK whereas 0:1 isn't. 1:1 and 0:0 are both OK
Posted: 04:12pm 11 Nov 2022
Either you are playing some 4D chess or I don't understand what you are trying to do (I favour the latter)
this is what I found:
OK_to_overwrite=((FlashByte AND ReplacementByte)=ReplacementByte)
Edited 2022-11-12 02:13 by CaptainBoing
Posted: 04:18pm 11 Nov 2022
OK - got it - thanks both
DaveJacko
Posted: 09:40pm 11 Nov 2022
in the 80's NOP was often h'00'
leading to the common phrase 'can you NOP it out?'
(writing video games in assembler in 2716 EEproms )
Try swapping 2 and 3 over
Posted: 01:31pm 12 Nov 2022
In my world NOP was &hEA
Posted: 03:13pm 12 Nov 2022
That's because you were a heathen and didn't worship at the church of the Holy Z80, Volhout.
Weren't the CPU wars fun?
Posted: 03:20pm 12 Nov 2022
... and the 8080/85 - of which admittedly the Z80 was a shameless rip
should I get me coat as later a NOP for me was 4E71 (ooh! 16 bit snob!)?
Edited 2022-11-13 01:35 by CaptainBoing
Posted: 05:27pm 12 Nov 2022
Yes.
