Local Time 07:50 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Backlight Spinbox on MM+ 2.8" ILI9341
Mickanical
Posted: 10:39am 07 Nov 2022
Hi Guys
I've updating an old Micromite backpack Sprinkler Control program to work on a MM+ backpack. Trying to make it look better.
I'm stuck on a Spinbox to control the backlight like Geoffs Pump control demo program.
I did the obvious thing... copying the relevant bits of code and massaging it to work on a smaller screen. Some bits of code only work with the SSD1963. Cannot remember which. I've learn't a fair bit going to and fro with the manual but no joy yet.
So I have the Spinbox code below. could you suggest where I've gone wrong please.
Thank you
Michael
'SPINBOX TESTING ON MM PLUS Backpack with 2.8" LCD
option explicit
dim integer TS_BRIGHT
TS_BRIGHT=51
CLS
GUI Interrupt TouchDown
PWM 2,100,TS_BRIGHT '
'PAGES SETUP
GUI SETUP 1 'PAGE 1 SETUP
GUI Caption #1, "Backlight", 22, 100, ,RGB(200,200,255),0
pause 1000  ' delay to help see whats going on
GUI Spinbox TS_BRIGHT, 10, 150, 200, 50,,,2, 2, 100
'CtrlVal(TS_BRIGHT) = 100
Do : Loop
Sub TouchDown
TEXT 10,10,STR$(ts_bright),LM,1,2,RGB(BLACK),RGB(GREEN)'Shows the value changing or not
'Case TS_BRIGHT ' the brightness spin box
'BackLight CtrlVal(TS_BRIGHT)
PWM 2,100,TS_bright
'END SELECT
Posted: 12:26pm 07 Nov 2022
The backlight command only works with the SSD1963 display and will give an error with any other type of display
void cmd_backlight(void) {
   if(HRes != 0 && Option.DISPLAY_TYPE > SSD_PANEL) error("SSD1963 display only");
   SetBacklightSSD1963(getint(cmdline, 0, 100));
However, this shouldn't be an issue. Just use a PWM pin to connect to the backlight pin on the display and change the PWM duty cycle in your code where you are currently using the BACKLIGHT command
Edited 2022-11-07 22:26 by matherp
