Forum Index : Microcontroller and PC projects : ili9488
Sorry . I found an ili9488 that looks pin compatible with ili9341 but does not work. Looks like problems.manual- OPTION LCDPANEL ILI9488, OR, DC, RESET, CS Initialises a TFT display using the ILI9488 controller. This supports 480 * 320 resolution. Note that this controller has an issue with the MISO pin which interferes with the touch controller. For this display to work the MISO pin must not be connected. Is this as problematic as the forum thread says? |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9260 |
The display controller isn't tri-stating the MISO line so nothing else can use it. Without MISO there's no feedback from the display, so there's no touch (or blit IIRC). Try fitting a 680R resistor between the display MISO and the PicoMite. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418 |
If you don't need Blit, pixel() or Image Save just leave LCD_SDO disconnected. To restore those functions without affecting touch connect that pin to the Pico MISO pin via a 680 ohm resistor. SD cards may also work, but not guaranteed. If SD access is unreliable with that fix replace the 680R with a switching transistor controlled by LCD_CS as shown here. A "Double Diode Switch" may also work. https://www.thebackshed.com/forum/ViewTopic.php?TID=11419&P=3#191429 Further info here. https://www.thebackshed.com/forum/ViewTopic.php?PID=193293#193293#192349 Edited 2022-10-28 06:43 by phil99 |
What variety of "does not work"? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Tinine Guru Joined: 30/03/2016 Location: United KingdomPosts: 1646 |
It may be the flash of light and small mushroom cloud that's stopping it. Mick Zilog Inside! nascom.info for Nascom & Gemini |
This in teraterm goes nowhere. > option clear Error : Invalid Option > option lcdpanel ili9488, l, gp15, gp14, gp13 Error : Display already configured option lcdpanel ili9488,l,gp15,gp,14,gp13 Error : Display already configured > OPTION LIST OPTION SYSTEM SPI GP18,GP19,GP16 OPTION CPUSPEED (KHz) 252000 OPTION LCDPANEL ILI9341, PORTRAIT,GP15,GP14,GP13 OPTION GUI CONTROLS 10 OPTION TOUCH GP12,GP11 GUI CALIBRATE 1, 197, 3854, 655, -897 OPTION SDCARD GP22 |
TeraTerm isn't the problem. You must be using the wrong manual. OPTION RESET will delete everything. To just change the display try:- OPTION LCDPANEL Disable then OPTION LCDPANEL ILI9488, RLANDSCAPE,GP15,GP14,GP13,GP7 GP7 goes to BL (BACK LIGHT control) or you can tie BL to 3V3. You will need to redo GUI CALIBRATE Or try this, it might be close enough. GUI CALIBRATE 0, 3820, 408, -1306, 946 Edited 2022-10-28 08:31 by phil99 |
It tells you (twice) what this particular form of "not working" is: "Error : Display already configured" If you can't find how to re-configure ("OPTION LCDPANEL DISABLE", as said above), you could always try re-flashing the firmware. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
... But for goodness sake make sure that you are using the correct manual for the version of the firmware that you are using. It's not just changes because of errors in the manual, there are changes in commands and how they are used too. Mick Zilog Inside! nascom.info for Nascom & Gemini |
I am using NON vga ie lcd version and thanks but not the brightest colour colour in the box. I wish I had not found this display but seems it works. Thanks for advice. |
It wasn't the VGA/non-VGA thing that I meant, it was the actual version number. The manuals are always behind the beta versions as it is but there's no need to make things any more difficult than you need to. :) Glad it's working now. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
