Local Time 09:41 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Unlikely BLIT command improvement?
vegipete
Posted: 07:27pm 15 Oct 2022
I expect this request wouldn't be a simple as I might think...
What is the chance of expanding the 'ORIENTATION' parameter of the BLIT command to include a few bits representing 'SCALE', much like the 'TEXT' command uses?
For example,
&B001000 - default scale of 1:1
&B010000 - scale 2 times larger
&B011000 - scale 3 times larger
&B111000 - scale 7 times larger
The scale value indicates how many times each pixel is repeated in the x and y directions.
An even crazier possibility would be separate fields for x and y scales. We can dream, can't we?
I'll go back to IMAGE RESIZE_FAST now.
Posted: 08:34pm 15 Oct 2022
You don't need this. Just put the image on a spare page and then resize it using image resize then load it as a sprite
vegipete
Posted: 05:24am 16 Oct 2022
After paying more attention to what I was reading in the description of the IMAGE RESIZE (& RESIZE_FAST) command, I see that it already does most of what I requested. There's no need to use a spare page or sprite-ification. Except maybe for speed issues.
The only missing part is horizontal and/or vertical mirroring. Allowing negative values for new_width and new_height could be used to indicate mirror.
