Local Time 10:34 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM.Devices$
Lightrock
Posted: 11:42am 02 Oct 2022
I am modifying a program for a '170 Micromite to run on a Picomite. I intended to use to MM.DEVICES$ command to confirm which device was connected. I could not get it to work so I tried entering the command from the command line but there was no response. I also tried the command on a 44 pin Micromite with no luck.
I tried other commands such as MM.INFO$(LCDPANEL), MM.VER and they worked as expected.
? MM.DEVICES$
> ? MM.DEVICES
Error : MM.DEVICES Different type already declared
> ? MM.info$(LCDPANEL)
ILI9341
What am I missing?
Roy
Posted: 11:44am 02 Oct 2022
You have an "S" at the end of your command; it's "?mm.device$"
Posted: 11:45am 02 Oct 2022
  Quote  What am I missing?
Nothing, but you are adding an S
? MM.DEVICE$
Lightrock
Posted: 10:18pm 02 Oct 2022
Thanks everyone. Reading too much into the command description.
