Local Time 10:37 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with INKEY$ (PicoMiteVGA V5.07.05RC4)
Frank N. Furter
Posted: 10:36am 30 Sep 2022
i tried to convert the fantastic program PicoMite Solar System Clock to PicoMiteVGA.
It works (with MODE 2) but I have problems with INKEY$. I use "+", "-" and "r" for resetting the time.
It works as expected with Tera Term but when I use the keyboard, the program does not accept any more characters after some inputs ("+"). Sometimes it still responds to "r".
Why???
With Tera Term it still continues to work flawlessly...
If anyone wants to try it, here is my modified code (at the moment it is not possible to reach all calendar days...):
' Converted to Pico MMBasic by Kevin Moore 07/12/2021
' Based on Python project https://github.com/dr-mod/pico-solar-system
' which uses the planetry equations of motion from http://stjarnhimlen.se/comp/tutorial.html
' I have limited the year between 1901 and 2100 as the equations may not work beyond these.
' Touch points are
' Top Left     = Brightness up
' Bottom Left  = Brightness down
' Top Right    = increase date by a week at a time then a month...
' Bottom Right = decrease date by a week at a time then a month...
' Centre       = reset back to todays date, also re-initialise LCD display
' turn off default typing
Option DEFAULT NONE
' force explicit typing
Option EXPLICIT
' turn off blinking LED while running
SetPin GP25, DOUT
' Screen = 320*240
Const width = 320
Const height = 240
Const onerad = 57.2957795131
Const update = 100
Colour RGB(WHITE), RGB(BLACK) ' Set the default colours
Font 1, 3 ' Set the default font
Dim m$(11) = ("Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec")
Dim planet_name$(9) = ("","Mercury","Venus","Earth","Mars","Jupiter","Saturn","Uranus","Neptune","Moon")
Dim STRING dy, TASTE
Dim INTEGER x, y, orbit, year, month, day, hour, min, today = 0, bright = 28
Dim INTEGER dayoff = 0, cuday, cumonth, cuyear, updatescr = update
Dim INTEGER last_pos(1,9)
Dim INTEGER rtcl=1 ' do we have a hardware real time clock
Dim FLOAT planets_dict(1,9)
Dim FLOAT xeclip, yeclip, zeclip, long2, lat2, r, Earthx, Earthy
Dim FLOAT feta, coordinatex, coordinatey, seconds, lastsec=60.0, frac_s=0.0
' set screen backlight to mid value
'Backlight bright
' Solar system centre
y = height / 2
x = y
 day = Eval(Left$(Date$, 2))
' only update planets daily or when changing or when fast scrolling
 If day <> today Or dayoff >= 2 Then
' re-initialise display once a day at midnight, when date changes
'    If dayoff <=1 Then GUI RESET LCDPANEL
   If dayoff <=4 Then CLS
   year = Eval(Right$(Date$, 4))
   month = Eval(Mid$(Date$, 4, 2))
   today = day
   hour = Eval(Left$(Time$, 2))
   min = Eval(Mid$(Time$, 4, 2))
' call main calculations of planet positions
   coordinates(year, month, day, hour, min) ' results returned in planets_dict array
' draw Sun
   If dayoff <=4 Then Circle x, y, 10, 0, 1,, RGB(YELLOW)
   For orbit = 1 To 9
' planet and orbit sizeing only for a 340*240 screen
' draw orbit rings
     r = 13 * orbit + 8
' change orbit spacing for inner planets
     If orbit <=3 Then r=r-7+(orbit*2) : If orbit >=2 Then r=r-3
' for speed, don't draw orbits if fast scrolling the date, no orbit for Moon
     If dayoff <= 2 And orbit <= 8 Then Circle x, y, r, 1, 1, RGB(BLUE), -1 : last_pos(0,orbit)=0 : last_pos(1 ,orbit)=0
' draw planets
' Moon Special is geocentric, all others are Heliocentric
     If orbit = 9 Then
' Don't draw Moon if fast scrolling
       If dayoff <= 2 Then
         feta = Atan2(planets_dict(1,orbit), planets_dict(0,orbit))+1.570796327
         r= 10 ' Moon orbit round Earth (keep it close)
         coordinatex = r * Sin(feta) + Earthx
         coordinatey = r * Cos(feta) + Earthy
         Call planet_name$(orbit) ,(coordinatex, coordinatey, last_pos(0,orbit), last_pos(1,orbit))
         last_pos(0,orbit) = coordinatex
         last_pos(1,orbit) = coordinatey
     Else
       feta = Atan2(planets_dict(0,orbit), planets_dict(1,orbit))
       coordinatex = r * Sin(feta) + x
       coordinatey = height - (r * Cos(feta) + y)
     If orbit = 3 Then Earthx=coordinatex : Earthy=coordinatey ' save Earth coordinates for Moon calcs.
   Next orbit
' display current date don't disply day of week if fast scrolling date
   If dayoff <= 2 Then
     dy$=Day$(Date$)
     If dy$="Wednesday" Then dy$="Wednesdy"
     Text 192, 22, dy$, "LB", 3, 1, RGB(ORANGE)
   Text 222, 28, Left$(Date$, 3)+m$(Eval(Mid$(Date$, 4, 2))-1), "LT", 3, 1, RGB(ORANGE)
   Text 252, 58, Right$(Date$,4), "LT", 3, 1, RGB(ORANGE)
' display current time and Pluto unless fast scrolling date
 If dayoff <= 2 Then
   seconds = Eval(Right$(Time$, 2))
   If lastsec > seconds Then Text 204, 212, Left$(Time$, 5), "LT", 7, 4, RGB(CYAN) : seconds=0 ' update time
   If seconds <> lastsec Then
     frac_s=0
     lastsec = seconds
   Else
     frac_s = frac_s+updatescr
   Pluto(seconds+(frac_s/1000))
 Pause updatescr ' wait before doing next screen update
 TASTE$ = INKEY$
 If  TASTE$ <> "" Then
   If TASTE$ = "+" Then
     If dayoff <97 Then day = day+1 Else month = month+1
     If day >28 Then day=1 : month = month+1
     If month >12 Then month=1 : year = year+1
'     If year > 2100 Then year = 2100
     updatescr=0
     lastsec=60
     dayoff = dayoff+3
     Date$ = Str$(day)+"/"+Str$(month)+"/"+Str$(year)
   If TASTE$ = "-" Then
     If dayoff <97 Then day = day-1 Else month = month-1
     If day <1 Then day=28 : month = month-1
     If month <1 Then month=12 : year = year-1
     If year <1901 Then year=1901
     updatescr=0
     lastsec=60
     dayoff = dayoff+3
   If TASTE$ = "r" Then
     updatescr = update
     dayoff = 0
     lastsec=60
     today=0
     If rtcl = 1 Then
       RTC GETTIME
     Else
       Date$ = Str$(cuday)+"/"+Str$(cumonth)+"/"+Str$(cuyear)
 ElseIf dayoff >2 Then
   dayoff = 2
 ElseIf dayoff =2 Then
   dayoff = 1
   updatescr = update  ' delay between screen updates & checking for push switches
Sub Pluto( secs As FLOAT )
Const  R = 4
Const  BOUNCE = -0.98
Static Float  plu_x = 290.0, plu_y = y
Static Float  xpos = plu_x, ypos=plu_y
Static Float  vel_x = -3.0
Static Integer  y_height = 124, y_min = 83
Static Integer  x_min = width-82 + R, x_max = width - R
Static Float amplitude, x_fun, sway, height, sec2
  If secs < 0.01 Then
    sec2=0
    vel_x = Rnd*3+4
    If Rnd > 0.5 Then vel_x = -(vel_x)
' update 59sec and 0 sec markers every minute.
    Text 236, 83, "0", "LB", 7, 1, RGB(156,166,183)
    Text 226, 210, "59", "LB", 7, 1, RGB(156,166,183)
' update the 30sec marker every 4 seconds while less than 35 seconds
  If secs >= sec2 And secs <= 35 Then sec2 = secs+2 : Text 308, 150, "30", "LB", 7, 1, RGB(156,166,183)
  amplitude = (60-secs)/60
  x_fun = secs - Fix( secs )
  sway = 1 - ((((x_fun/0.5)-1)^2) * (-1) + 1)
  height = y_height * amplitude
  plu_y = (height * sway) + y_height - height + y_min
  plu_x = plu_x + vel_x
  If plu_x >= x_max Then
      vel_x = vel_x * BOUNCE
      plu_x = x_max
  ElseIf plu_x <= x_min Then
      plu_x = x_min
  Box xpos-4, ypos-4, 9, 9, 0,, RGB(0,0,0)  ' blank Pluto
  Circle plu_x, plu_y, R, 0, 1,, RGB(156,166,183)  'Pluto
  xpos = plu_x
  ypos = plu_y
Sub Mercury(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-2, ypos-2, 5, 5, 0,, RGB(0,0,0)  ' blank Mercury
  Circle xs, ys, 2, 0, 1,, RGB(213,178,138)  'Mercury
Sub Venus(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-4, ypos-4, 9, 9, 0,, RGB(0,0,0)  ' blank Venus
  Circle xs, ys, 4, 0, 1,, RGB(179,102,22)  'Venus
Sub Earth(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-6, ypos-6, 13, 13, 0,, RGB(0,0,0)  ' blank Earth
  Circle xs, ys, 6, 0, 1,, RGB(126,152,203)  'Earth
' don't draw planet details if fast scrolling
  If dayoff <=2 Then
    Line xs-1,ys-6, xs+1,ys-6, 1, RGB(WHITE)
    Line xs-3,ys+5, xs+3,ys+5, 1, RGB(WHITE)
    Line xs-1,ys+6, xs+1,ys+6, 1, RGB(WHITE)
    Circle xs+1,ys+1, 3, 2, 1.5, RGB(230,230,250), -1
    Circle xs-2, ys-1, 4, 0, 0.6,, RGB(30,255,20)
Sub Mars(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-3, ypos-3, 7, 7, 0,, RGB(0,0,0)    ' blank Mars
  Circle xs, ys, 3, 0, 1,, RGB(234,169,111)    'Mars
Sub Jupiter(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-7, ypos-7, 15, 15, 0,, RGB(0,0,0)  ' blank Jupiter
  Circle xs, ys, 7, 0, 1,, RGB(185,191,153)  'Jupiter
  If dayoff <=2 Then
    Line xs-5,ys-5,xs+5,ys-5, 1, RGB(182,134,86)
    Line xs-7,ys-3,xs+7,ys-3, 2, RGB(182,134,86)
    Line xs-7,ys+1,xs+7,ys+1, 2, RGB(202,150,100)
    Line xs-5,ys+5,xs+5,ys+5, 1, RGB(202,150,100)
    Circle xs+2,ys+2, 2, 0, 1.75,, RGB(230,144,91)
Sub Saturn(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-7, ypos-7, 15, 15, 0,, RGB(0,0,0) ' blank Saturn
  Line xpos-14, ypos, xpos+14, ypos, 2, RGB(0,0,0)
  Circle xs, ys, 6, 0, 1,, RGB(222,182,113) 'Saturn
  Line xs-14, ys, xs+14, ys, 2, RGB(141,124,104)
Sub Uranus(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-5, ypos-5, 11, 11, 0,, RGB(0,0,0)   ' blank Uranus
  Circle xs, ys, 5, 0, 1,, RGB(173,217,244)   'Uranus
Sub Neptune(xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
  Box xpos-5, ypos-5, 11, 11, 0,, RGB(0,0,0)    ' blank Neptune
  Circle xs, ys, 5, 0, 1,, RGB(116,142,193)    'Neptune
Sub Moon( xs As INTEGER, ys As INTEGER, xpos As INTEGER, ypos As INTEGER)
   Box xpos-2, ypos-2, 5, 5, 0,, RGB(0,0,0)    ' blank Moon
   Circle xs, ys, 2, 0, 1,, RGB(250,250,250)    'Moon
'Function Modulus(angle As FLOAT) As FLOAT
'    Modulus = angle - Int(angle/360.0)*360.0
'End Function
Sub from_sun(m As FLOAT, e As FLOAT, a As FLOAT, ns As FLOAT, w As FLOAT, ic As FLOAT)
Local FLOAT m2, e0, e02, e1, x, y, r, vs, vc, nc
   m2 = Rad(m)
   e0 = (m + onerad * e * Sin(m2) * (1 + e * Cos(m2))) Mod 360
   e02 = Rad(e0)
   e1 = Rad((e0 - (e0 - onerad * e * Sin(e02) - m) / (1 - e * Cos(e02))) Mod 360)
   x = a * (Cos(e1) - e)
   y = a * (Sqr(1 - e * e)) * Sin(e1)
' return value r
   r = Sqr(x * x + y * y)
   vs = Rad((Deg(Atan2(y, x)) Mod 360) + w)
   vc = Cos(vs)
   vs = Sin(vs)
   ns = Rad(ns)
   nc = Cos(ns)
   ns = Sin(ns)
   zeclip = r * vs * Sin(Rad(ic))
   ic = Cos(Rad(ic))
' return values xeclip, yeclip, long2, lat2
   xeclip = r * (nc * vc - ns * vs * ic)
   yeclip = r * (ns * vc + nc * vs * ic)
   long2 = (Deg(Atan2(yeclip, xeclip))) Mod 360
   lat2 = Deg(Atan2(zeclip, Sqr(xeclip * xeclip + yeclip * yeclip)))
' results returned in array planets_dict
Sub coordinates(year%, month%, day%, hour%, minute%)
Local INTEGER jdn
Local FLOAT jd, d, w, e, m2, m, e_capt, x, y, r, v, lon, x2, y2
Local FLOAT n_mo, i_mo, w_mo, a_mo, e_mo, m_mo
Local FLOAT n_er, i_er, w_er, a_er, e_er, m_er
Local FLOAT n_af, i_af, w_af, a_af, e_af, m_af
Local FLOAT n_ar, i_ar, w_ar, a_ar, e_ar, m_ar
Local FLOAT n_di, i_di, w_di, a_di, e_di, m_di
Local FLOAT n_kr, i_kr, w_kr, a_kr, e_kr, m_kr
Local FLOAT n_ou, i_ou, w_ou, a_ou, e_ou, m_ou
Local FLOAT n_po, i_po, w_po, a_po, e_po, m_po
Local FLOAT di_diat1, di_diat2, di_diat3, di_diat4, di_diat5, di_diat6, di_diat7
Local FLOAT kr_diat1, kr_diat2, kr_diat3, kr_diat4, kr_diat5, kr_diat6, kr_diat7
Local FLOAT ou_diat1, ou_diat2, ou_diat3
Local FLOAT diataraxes_long_di, diataraxes_long_kr, diataraxes_lat_kr, diataraxes_long_ou
Local FLOAT long2_di, coslat2_di, r_di, long2_kr, coslat2_kr, r_kr
Local FLOAT long2_ou, coslat2_ou, r_ou
   jdn = ((367*year%-(7*(year%+((month%+9)\12))\4))+(275*month%\9)+(day%+1721013.5))
   jd = (jdn + hour% / 24. + minute% / 1440.)
   d = jd - 2451543.5
   w = 282.9404 + 4.70935E-5 * d
   e = (0.016709 - (1.151E-9 * d))
   m2 = (356.047 + 0.9856002585 * d) Mod 360
   m = Rad( m2 )
   e_capt = Rad(m2 + onerad * e * Sin(m) * (1 + e * Cos(m)))
   x = Cos(e_capt) - e
   y = Sin(e_capt) * Sqr(1 - e * e)
   v = Deg(Atan2(y, x))
   lon = Rad((v + w) Mod 360)
   x2 = r * Cos(lon)
   y2 = r * Sin(lon)
' Earth coords
   planets_dict(0,3) = -1 * x2
   planets_dict(1,3) = -1 * y2
   n_mo = 125.1228 - 0.0529538083 * d    '  (Long asc. node)
   i_mo = 5.1454                         '  (Inclination)
   w_mo = 318.0634 + 0.1643573223 * d    '  (Arg. of perigee)
   a_mo = 60.2666                        '  (Mean distance)
   e_mo = 0.054881                       '  (Eccentricity)
   m_mo = (115.3654 + 13.0649929509 * d) Mod 360 '  (Mean anomaly)
   n_er = 48.3313 + 3.24587E-5 * d
   i_er = 7.0047 + 5.00E-8 * d
   w_er = 29.1241 + 1.01444E-5 * d
   a_er = 0.387098
   e_er = 0.205635 + 5.59E-10 * d
   m_er = (168.6562 + 4.0923344368 * d) Mod 360
   n_af = 76.6799 + 2.46590E-5 * d
   i_af = 3.3946 + 2.75E-8 * d
   w_af = 54.8910 + 1.38374E-5 * d
   a_af = 0.723330
   e_af = 0.006773 - 1.30E-9 * d
   m_af = (48.0052 + 1.6021302244 * d) Mod 360
   n_ar = 49.5574 + 2.11081E-5 * d
   i_ar = 1.8497 - 1.78E-8 * d
   w_ar = 286.5016 + 2.92961E-5 * d
   a_ar = 1.523688
   e_ar = 0.093405 + 2.51E-9 * d
   m_ar = (18.6021 + 0.5240207766 * d) Mod 360
   n_di = 100.4542 + 2.76854E-5 * d
   i_di = 1.3030 - 1.557E-7 * d
   w_di = 273.8777 + 1.6450E-5 * d
   a_di = 5.20256
   e_di = 0.048498 + 4.469E-9 * d
   m_di = (19.8950 + 0.0830853001 * d) Mod 360
   n_kr = 113.6634 + 2.38980E-5 * d
   i_kr = 2.4886 - 1.081E-7 * d
   w_kr = 339.3939 + 2.97661E-5 * d
   a_kr = 9.55475
   e_kr = 0.055546 - 9.499E-9 * d
   m_kr = (316.9670 + 0.0334442282 * d) Mod 360
   n_ou = 74.0005 + 1.3978E-5 * d
   i_ou = 0.7733 + 1.9E-8 * d
   w_ou = 96.6612 + 3.0565E-5 * d
   a_ou = 19.18171 - 1.55E-8 * d
   e_ou = 0.047318 + 7.45E-9 * d
   m_ou = (142.5905 + 0.011725806 * d) Mod 360
   n_po = 131.7806 + 3.0173E-5 * d
   i_po = 1.7700 - 2.55E-7 * d
   w_po = 272.8461 - 6.027E-6 * d
   a_po = 30.05826 + 3.313E-8 * d
   e_po = 0.008606 + 2.15E-9 * d
   m_po = (260.2471 + 0.005995147 * d) Mod 360
   from_sun(m_mo, e_mo, a_mo, n_mo, w_mo, i_mo)
   planets_dict(0,9) = xeclip
   planets_dict(1,9) = yeclip
' return values in xeclip, yeclip, long2, lat2, r
   from_sun(m_er, e_er, a_er, n_er, w_er, i_er)
   planets_dict(0,1) = xeclip
   planets_dict(1,1) = yeclip
   from_sun(m_af, e_af, a_af, n_af, w_af, i_af)
   planets_dict(0,2) = xeclip
   planets_dict(1,2) = yeclip
   from_sun(m_ar, e_ar, a_ar, n_ar, w_ar, i_ar)
   planets_dict(0,4) = xeclip
   planets_dict(1,4) = yeclip
   from_sun(m_di, e_di, a_di, n_di, w_di, i_di)
   long2_di = long2
   coslat2_di = Cos(Rad(lat2))
   r_di = r
   from_sun(m_kr, e_kr, a_kr, n_kr, w_kr, i_kr)
   long2_kr = long2
   coslat2_kr = lat2
   r_kr = r
   from_sun(m_ou, e_ou, a_ou, n_ou, w_ou, i_ou)
   long2_ou = long2
   coslat2_ou = Cos(Rad(lat2))
   r_ou = r
   from_sun(m_po, e_po, a_po, n_po, w_po, i_po)
   planets_dict(0,8) = xeclip
   planets_dict(1,8) = yeclip
   m_di = m_di Mod 360
   m_kr = m_kr Mod 360
   m_ou = m_ou Mod 360
   di_diat1 = -0.332 * Sin(Rad(2 * m_di - 5 * m_kr - 67.6))
   di_diat2 = -0.056 * Sin(Rad(2 * m_di - 2 * m_kr + 21))
   di_diat3 = 0.042 * Sin(Rad(3 * m_di - 5 * m_kr + 21))
   di_diat4 = -0.036 * Sin(Rad(m_di - 2 * m_kr))
   di_diat5 = 0.022 * Cos(Rad(m_di - m_kr))
   di_diat6 = 0.023 * Sin(Rad(2 * m_di - 3 * m_kr + 52))
   di_diat7 = -0.016 * Sin(Rad(m_di - 5 * m_kr - 69))
   kr_diat1 = 0.812 * Sin(Rad(2 * m_di - 5 * m_kr - 67.6))
   kr_diat2 = -0.229 * Cos(Rad(2 * m_di - 4 * m_kr - 2))
   kr_diat3 = 0.119 * Sin(Rad(m_di - 2 * m_kr - 3))
   kr_diat4 = 0.046 * Sin(Rad(2 * m_di - 6 * m_kr - 69))
   kr_diat5 = 0.014 * Sin(Rad(m_di - 3 * m_kr + 32))
   kr_diat6 = -0.02 * Cos(Rad(2 * m_di - 4 * m_kr - 2))
   kr_diat7 = 0.018 * Sin(Rad(2 * m_di - 6 * m_kr - 49))
   ou_diat1 = 0.04 * Sin(Rad(m_kr - 2 * m_ou + 6))
   ou_diat2 = 0.035 * Sin(Rad(m_kr - 3 * m_ou + 33))
   ou_diat3 = -0.015 * Sin(Rad(m_di - m_ou + 20))
   diataraxes_long_di = (di_diat1 + di_diat2 + di_diat3 + di_diat4 + di_diat5 + di_diat6 + di_diat7)
   diataraxes_long_kr = (kr_diat1 + kr_diat2 + kr_diat3 + kr_diat4 + kr_diat5)
   diataraxes_lat_kr = (kr_diat6 + kr_diat7)
   diataraxes_long_ou = (ou_diat1 + ou_diat2 + ou_diat3)
   long2_di = Rad(long2_di + diataraxes_long_di)
   long2_kr = Rad(long2_kr + diataraxes_long_kr)
   coslat2_kr  = Cos(Rad(coslat2_kr + diataraxes_lat_kr))
   long2_ou = Rad(long2_ou + diataraxes_long_ou)
   planets_dict(0,5) = r_di * Cos(long2_di) * coslat2_di
   planets_dict(1,5) = r_di * Sin(long2_di) * coslat2_di
   planets_dict(0,6) = r_kr * Cos(long2_kr) * coslat2_kr
   planets_dict(1,6) = r_kr * Sin(long2_kr) * coslat2_kr
   planets_dict(0,7) = r_ou * Cos(long2_ou) * coslat2_ou
   planets_dict(1,7) = r_ou * Sin(long2_ou) * coslat2_ou
Frank
Posted: 11:33am 30 Sep 2022
Set OPTION CPUSPEED 378000 and that seems to solve it. All I can assume is that the firmware is dropping H/W interrupts possibly because there is so much FP going on.
You can make the display much better with
FRAMEBUFFER create
FRAMEBUFFER write f
FRAMEBUFFER copy f,n
Out of interest try
PicoMiteVGA.zip
which seems somewhat better to me
Originally I was copying the RP2040 FP routines from its ROM to RAM for performance reasons as part of the linker options. In this version I run them directly from ROM. In the RAM version the ROM has a stub which calls the RAM copy (it is an official option) but it may be there is some additional interaction with H/W interrupts
Frank N. Furter
Posted: 11:49am 30 Sep 2022
Hi Peter,
I tried your version - it seems to be better. It also works better with OPTION CPUSPEED 378000, but the program also hangs after a while...
Could the input be solved more elegantly?
THANKS!
Frank
Posted: 05:35pm 30 Sep 2022
Hi Frank, Peter,
I tried to duplicate Franks problem, but on my platform (GAMEpicoVGA 1.4) with my keyboard, I cannot duplicate the original problem.
OPTIONS:
option list
PicoMiteVGA MMBasic Version 5.07.05RC4
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION SDCARD GP13, GP11, GP12, GP10
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
OPTION F5 mode 1:edit
Is there something you want met to try to get to the bottom of this ?
Could the problem lie in de PS2 key repeat, or in the PS2 clock speed, the language (DE) ? The waveforms look pristine (nice squarewaves on both 3.3V and 5V side of the level shifter).
Just let me know...
Edited 2022-10-01 03:38 by Volhout
Frank N. Furter
Posted: 11:57am 02 Oct 2022
Hi Volhout,
here are my options:
option list
OPTION SYSTEM I2C GP14,GP15
OPTION KEYBOARD GR
OPTION DISPLAY 60, 106
OPTION SDCARD GP13, GP10, GP11, GP12
OPTION RTC AUTO ENABLE
OPTION DEFAULT FONT 7, 1
I don't think it's because of the PS2 key repeat, or in the PS2 clock speed. I have the same problem (at default speed) when I press the "+" key about 10-15 times at a second interval.
Suddenly, the key no longer responds! It still works via terminal. Sometimes it works again when I then press "-" or "r". If interrupts are lost, shouldn't the system hang???
If I then repeatedly press "+" on the keyboard, I have the same problem again...
There are no difficulties with you? Strange!!!
Can you maybe activate a RTC in your system?
Frank
Frank N. Furter
Posted: 07:38am 04 Oct 2022
...is it possible that we have a firmware problem after all?
I had the INKEY characters printed out once - after some time I only get an "l" back when I press "+".
Especially it seems to get better if I set the repeatrate under OPTION KEYBOARD to "0"??? Shouldn't it get worse there???
Frank
Posted: 07:49am 04 Oct 2022
If you want this looked at you need to produce a small demonstration program that I can work with.
Have you tested with different PS2 keyboards?
Posted: 07:56pm 04 Oct 2022
Frank,
The picomite consists of a cpu module on a circuit board. To connent to the keyboard you need power and a 5V logic serial bus.
Old keyboards definitely need 5V power (more than 4.75V). Can you check if the 5V on the ps2 connector is 4.75V?
Then the 5V serial bus is created using a level shifter circuit (the pico is 3.3V). Do you use a le el shifter module? Or do you use discrete FET's?
Can you check that the level shifter works. (Without keyboard attached, are the clock and data pin 5V?).
If you use discrete FETs, are they in the correct orientation.? Maybe send a photo, and the type number of the parts used. It could be they are mounted reversed (there are different connections for parts that look the same from the outside).
From what you are saying, this could be a hardware problem, that is why the above questions.
Finally you could check what happens when you switch the keyboard option to US or UK (this is the default). If behaviour changes then we know where to look for.
Edited 2022-10-05 06:15 by Volhout
Posted: 08:49pm 04 Oct 2022
I'd definitely look at the keyboard voltage - remembering that you can't power the keyboard from 5V (which it may need) and connect it direct to the Picomite pins!
Some PS/2 keyboards are partially functional at 3V3 but not reliable.
Also, if there is a level shifter using 2N7000 MOSFETs you need to note that in the usual circuit they are actually being asked to work out of specification - but they usually do in my experience.
Are you using one of the known PicoMite VGA PCBs Frank?
Posted: 09:29pm 04 Oct 2022
  Quote  Also, if there is a level shifter using 2N7000 MOSFETs
Also note 2N7000 do not guarantee to meet the spec in the application note. The mosfet I specify do.
Frank N. Furter
Posted: 06:45am 05 Oct 2022
I have a PicoMiteVGA V1.3 PCB with two TN0702N3-G:
I have no other problems with the keyboard - I had used it successfully on all projects so far (Maximite, Duinomite, Colormaximite, Colormaximite2). It is a CHERRY G84-4100.
Am I the only one who has this problem with the above code???
I will try other keyboards and completely reset and reflash the µC.
Frank
Posted: 09:52am 05 Oct 2022
Hi Frank,
I tried your code on the same picomite PCB (Peter's design 1.4) and cannot reproduce your problem. Used a small PS2 keyboard. Both with key repeat, and with single key presses the data changes, as does the clock.
Tried with a different (older) PS2 keyboard. I can see no problems. There must be something related to your keyboard (since we use the same picomite platform).
Did you measure the voltage at the PS2 connector ? Looks like you power from the barrel connector. What diode do you use for D1 ? iN5819? Or 1N4001 ?
Martin H.
Posted: 11:00am 05 Oct 2022
  Volhout said  Hi Frank,
I've done the same with the PicoMite Game Board (with 2N7000 transistors) a new PS2 keyboard. The Program runns without errors
MMBasic 5.07.05RC6, CLOCKSPEED 378000  and the Modefication that Peter suggested.
Maybee there is something (special) with your Keyboard .
 Mart!n
btw: Nice little Program
Edited 2022-10-05 21:11 by Martin H.
'no comment
